Fuel vapor separator #1429989
05/03/13 10:53 PM
05/03/13 10:53 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
I know there are two different versions: one for a Hemi and one for a 440 Six Pack. The 440 version has a slightly longer mounting bracket. Are they interchangeable?
Re: Fuel vapor separator [Re: moparcanuk] #1429990
05/04/13 09:00 AM
05/04/13 09:00 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1968 to 1971 both 440 and hemi take the same seperator 1972 uses the one with the longer bracket. then 1973 uses an even longer bracket
But to answer the question, Yes they will interchange if you have one and not the other
Re: Fuel vapor separator [Re: gtx6970] #1429991
05/04/13 11:36 AM
05/04/13 11:36 AM
Orleans, Ontario
Orleans, Ontario
Thanks!
Re: Fuel vapor separator [Re: moparcanuk] #1429992
05/04/13 12:09 PM
05/04/13 12:09 PM
Orleans, Ontario
Orleans, Ontario
Re: Fuel vapor separator [Re: moparcanuk] #1429993
05/04/13 12:34 PM
05/04/13 12:34 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Hopefully you did a search and know there are good and bad separators? Orfice size is important.
Re: Fuel vapor separator [Re: drew72] #1429994
05/05/13 12:53 AM
05/05/13 12:53 AM
Orleans, Ontario
Orleans, Ontario
What's the difference between a good and bad separator?
Re: Fuel vapor separator [Re: moparcanuk] #1429995
05/05/13 03:24 AM
05/05/13 03:24 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That is a good price. I think mine cost around $55?
Not sure I would worry too much about the restriction size, you can install a restriction in the return line if needed.
Re: Fuel vapor separator [Re: moparcanuk] #1429996
05/05/13 10:17 AM
05/05/13 10:17 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Some good info here;
https://board.moparts.org/ubbthreads/show...e=0#Post7255403
Re: Fuel vapor separator [Re: moparfan53] #1429997
05/05/13 11:16 PM
05/05/13 11:16 PM
Orleans, Ontario
Orleans, Ontario
So is it the consensus that the repros are crap and not to buy them?
