Re: Rod Ratio
[Re: MoparMarz]
#1429654
05/03/13 03:08 PM
05/03/13 03:08 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
What are the premium bore to stroke ratio and the rod to stroke ratio when building a stroker 340, stroke is 4.125 with a 6.2 rod and a 4.125 bore.
Sounds like you already have the crank and rods so the option of optimizing the stroke/rod length ratio is not possible, unless you want to buy another set of rods I've heard from 1.60 to 1.80 ratio is best with 1.75 as the best, I understand the NHRA Pro Stock motors are near 1.82 to 1 ratio or higher Your current parts = 4.125 divided into 6.20 = 1.503 ratio I built a 4.00 inch stroke 340 block yeas ago for pump gas street use with NOS at the track, it is still runiing today, lots of street miles and a lot of hard passes on it. it has a set of stock length and spec. Eagle H beam rods in it 4.0 divided into 6.123 = 1.530 ratio Run it if you want, change it if you want The longer rod will help make the piston lighter also
