B-body door hinge replacement or pins? #1429376
05/02/13 08:38 PM
05/02/13 08:38 PM
illinois
bigblk66_coronet Offline OP
illinois
The drivers door hinge on my 66 Coronet are getting real week......lots of slop and hard to close the door. Have and of you guys replaced the pins in the higes before? If you have how well did it work? Or would i just be better off to buy new hinges?........joe
Re: B-body door hinge replacement or pins? [Re: bigblk66_coronet] #1429377
05/02/13 08:57 PM
05/02/13 08:57 PM
car48nut Offline
car48nut  Offline
buy new hinges. The time that you waste will pay for the hinges.
Re: B-body door hinge replacement or pins? [Re: car48nut] #1429378
05/02/13 09:03 PM
05/02/13 09:03 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
If the hinges are only worn to the size of the bushing you install, then replace the bushings/pins. If however the hole is larger, or oblong excessively then there really is no other option except to replace.
Curt
Of course you could weld up the holes and re-drill them, just not too much fun
Oh yeah...THAT'S gonna leave a mark!
Re: B-body door hinge replacement or pins? [Re: Curt] #1429379
05/03/13 03:10 AM
05/03/13 03:10 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Curt
I've repaired my own for eons..
Stainless steel round stock and drilled out for the pin size... and cut them at 1/2" lengths. Then I weld 2 per hinge to give the stock pins support at the bad area and plus... they will never wear out
Mostly have to repair only one door hinge(large one) and also.. it's hidden
