Odometer Reading Vote #1428816
05/01/13 08:09 PM
05/01/13 08:09 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
OK, total restoration, nut and bolt, when the odometer wheels are redone do you leave the original miles or roll it to zero?
No right or wrong, not wanting any fights, just opinions.
If it matters, AAR, 76k
I'd set the odometer to
single choice
Votes accepted starting: 05/01/13 07:06 PM
You must vote before you can view the results of this poll.
Re: Odometer Reading Vote [Re: AAR#2] #1428817
05/01/13 10:13 PM
05/01/13 10:13 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I had mine put back to the correct mileage. They are only original once.
Re: Odometer Reading Vote [Re: burdar] #1428818
05/01/13 10:39 PM
05/01/13 10:39 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
original running gear , i leave the odometer the same. not original with a fresh non numbers engine , i set it back to 0.
Re: Odometer Reading Vote [Re: 2abodymcodes] #1428819
05/01/13 11:39 PM
05/01/13 11:39 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
What use is original mileage if one rebuilds entire drive train and suspension even if it is a number matching car?
The odometer no longer reflects the usage on the parts.
Put it to zero to reflect a fresh start.
Jules
Re: Odometer Reading Vote [Re: AAR#2] #1428820
05/01/13 11:44 PM
05/01/13 11:44 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Given your very specific "nut and bolt" definition I say reset to zero...........with a lot of hesitation-------if the car remains intact, and it the original odo to the car, why not leave it alone?
Re: Odometer Reading Vote [Re: Pacnorthcuda] #1428821
05/02/13 08:26 AM
05/02/13 08:26 AM
My personal thought would be to keep it with the mileage that it has. Reasoning for this is you might run into a problem if you should ever sell the car and the title not match what the odometer shows and then would have to get a title that says modified mileage or something to that extent.
Re: Odometer Reading Vote [Re: ] #1428822
05/02/13 08:46 AM
05/02/13 08:46 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I would perhaps pencil down or put a tag with the original mileage on the back of the dash somewhere with a date and some info explaining that was the last known mileage since the reset to 0.
Re: Odometer Reading Vote [Re: BigBlockMopar] #1428823
05/02/13 10:38 AM
05/02/13 10:38 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Indiana law FYI:
Information Maintained by the Office of Code Revision Indiana Legislative Services Agency
IC 9-19-9
Chapter 9. Odometers
IC 9-19-9-1
Advertising, sale, use, or installation of devices causing odometers to misregister mileage
Sec. 1. A person may not:
(1) advertise for sale;
(2) sell;
(3) use; or
(4) install;
any device that causes an odometer to register mileage other than the mileage driven by the vehicle as registered by the odometer within the manufacturer's designed tolerance.
As added by P.L.2-1991, SEC.7.
IC 9-19-9-2
Disconnecting, resetting, or altering odometer
Sec. 2. A person may not:
(1) disconnect;
(2) reset; or
(3) alter;
the odometer of any motor vehicle with intent to change the number of miles indicated on the odometer.
IC 9-19-9-3
Operation of vehicle with disconnected or nonfunctional odometer
Sec. 3. (a) This section applies to all motor vehicles except the following:
(1) Motorcycles.
(2) Trucks the declared gross weight of which exceeds eleven thousand (11,000) pounds.
(3) Motor vehicles that have a model year on their registration card that is at least five (5) years earlier than the year the vehicle is in operation on a street or highway.
(b) A person may not knowingly operate a motor vehicle on a street or highway if the odometer of the vehicle is disconnected or nonfunctional.
IC 9-19-9-4
Service, repair, or replacement of odometer
Sec. 4. This chapter does not prohibit the service, repair, or replacement of an odometer if the mileage indicated on the odometer remains the same as before the service, repair, or replacement. If the odometer is incapable of registering the same mileage as before the service, repair, or replacement, the odometer shall be adjusted to read zero (0) and a notice in writing shall be attached to the left door frame of the vehicle by the owner or the owner's agent specifying the
mileage before repair or replacement of the odometer and the date on which the odometer was repaired or replaced. A person may not knowingly remove or alter a notice affixed to a motor vehicle under this section.
IC 9-19-9-5
Fraudulent violations and omissions; classification of offense
Sec. 5. A person who, with intent to defraud:
(1) violates this chapter; or
(2) omits to do any act that is required by this chapter;
commits a Class D felony.
IC 9-19-9-6
Corporate directors, officers, or agents; criminal liability
Sec. 6. An individual director, officer, or agent of a corporation who authorizes, orders, or performs any of the acts or practices prohibited by this chapter is subject to criminal liability in accordance with IC 35-41-2-4.
IC 9-19-9-7
Deceptive acts; civil penalties; recovery by attorney general
Sec. 7. A person who:
(2) violates 49 U.S.C. 32709 (as in effect January 1, 1995);
commits a deceptive act and is subject to a civil penalty of not more than one thousand five hundred dollars ($1,500) for each violation in addition to other remedies available under this chapter and IC 24-5-0.5. The attorney general, acting in the name of the state, has the exclusive right to petition for recovery of such a penalty, and the penalty may be recovered only in an action brought under IC 24-5-0.5-4(c).
As added by P.L.2-1991, SEC.7. Amended by P.L.54-2009, SEC.4.
Re: Odometer Reading Vote [Re: Dave Watt] #1428824
05/02/13 07:11 PM
05/02/13 07:11 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Dave, interesting reading and by no means would I condone anyone doing anything illegal in their home of residence. Interestingly enough AZ has similar wording but doesn't seem to care much about cars 10 years and older. Here is what I found on a questions and answers section;
Q. Why are vehicles 10 years old and older exempted?
A. NHTSA says odometer fraud is not a major factor in the price of those automobiles, and is more common in newer vehicles.
So it's really about resale value and the perception of what John Q Public is buying/paying based on milage perception. In this hobby, I doubt anyone will think my car has 76k original miles or 0 miles when I'm finished.
Everyone who's responded has made great arguments for their belief, unfortunately I'm still unsure what I will do. Either way you can bet the cars original milage will not be lost.
Re: Odometer Reading Vote [Re: AAR#2] #1428825
05/02/13 10:37 PM
05/02/13 10:37 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If it was over 100,000 I would say go back to zero.
But, at 76,000 leave it.
Your entire resto will be documented at that point anyway. To me, a car with less than 100,000 original miles carries alot of weight, more so than "numbers matching drivetrain". At 76k many of the pieces you take off should be able to be cleaned/polished/painted back up and put back on which (to me) preserves the originality. When I'm buying cars I look for originality and straightness of the body, I could care less if the engine's been swapped 20 times.
Mo' Farts
Moderated by "tbagger".
