every one told me the frame did not change in 88.
I begged to differ then. and again now.
I un-bolted a set of mounts from my 88 frame for mopar jamie to swap a V-8 in his truck.
and the frame was not like the 85 with the 2 sets of holes used for /6,SB,BB engines.
with the bolt in mount removed there was no part of the frame to bolt anything too.
Bouchillon has the foot note on the BB swap kit that it fits up to a 87 truck only for a reason.
maybe some trucks got the 'good' frames till they were used up.
anyone got a 88-93 2x SB engine in a truck? how different are the 92-93 truck with mag engines? do they use a mid block mount like a DAK?
this sure sux for Dave to find out in the middle of the swap
