oil pressure issues #1428239
04/30/13 07:30 PM
04/30/13 07:30 PM
Champion City
The Sphinx Offline OP
Champion City
I've rebuilt a few small blocks in the past and never had an issue like this. I primed the oil system and fired up the engine and it maintained (cold 75PSI) (hot 40PSI) at 2000 RPM. Now my issue is at idle my pressure drops down to 15PSI regardless of it being hot or cold.
I use a snap-on 1200 RPM drill on an old distributor that has been lengthened to reach the oil pump as a priming tool.
What I noticed that is strange is:
1) When priming it, it takes about 3 seconds to feel any resistance in the drill. If you stop and start the drill again a few seconds later it still takes about 3 seconds to feel any back pressure on the drill. Like the pump is loosing its prime.
2) When I prime it and get the oil pressure up to any pressure and then stop, you can hear the sound of oil pouring into the pan. It sounds more like pressurized oil dumping.
I've checked the gallery plugs, they are all in. The oil pump pick up is just shy of 1/4 off the bottom of the pan.
What else should I check? I'm down to thinking it's either a bad pump (Melling M72), gasket between pump and main cap poo pooed on my, or a leak between the pick up and the pump.
Any other guesses?
For the heck of it I primed the system on an old 360 I rebuilt several years ago and noticed once It's primed and I reprime I get instant pressure and resistance on my drill.
Once I stop priming you can hear a slight trickle of the oil back to the pan.
Re: oil pressure issues [Re: The Sphinx] #1428240
04/30/13 07:41 PM
04/30/13 07:41 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
oil pump pressure relief valve? spring - as in none? broken? too short?
what do you know about the oil pump?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: oil pressure issues [Re: The Sphinx] #1428241
04/30/13 07:44 PM
04/30/13 07:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not a Mopar engine is it?
My guess is it's a Fram filter with a bad anti drain back valve.
Don't be the exception.
Re: oil pressure issues [Re: VincentVega] #1428242
04/30/13 09:14 PM
04/30/13 09:14 PM
Champion City
Champion City
Brand new Melling M72
Re: oil pressure issues [Re: Supercuda] #1428243
04/30/13 09:16 PM
04/30/13 09:16 PM
Champion City
Champion City
Mopar small block, I only use WIX oil filters.
Re: oil pressure issues [Re: The Sphinx] #1428244
04/30/13 09:34 PM
04/30/13 09:34 PM
I've checked the gallery plugs, they are all in. What else should I check?
Did that include the gallery plug that goes in the rear of the DR horizontle oil gallery inside the valley?
Re: oil pressure issues [Re: RapidRobert] #1428245
05/01/13 09:09 AM
05/01/13 09:09 AM
Champion City
Champion City
checked
Re: oil pressure issues [Re: The Sphinx] #1428246
05/01/13 09:26 AM
05/01/13 09:26 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The oil galley plug on the back driver side that is right inside the engine?? you have to remove plug in back of engine to get to it or have intake off and feel down in there!
machine shops are good at taking it out not so good putting it back sometimes!
rocker shafts have holes down?
Re: oil pressure issues [Re: The Sphinx] #1428247
05/01/13 10:16 AM
05/01/13 10:16 AM
I think 15 at idle is acceptable (barely) as long as it jumps up immediately when you gun it. You might double check with another mechanical gauge. There might be excessive clearances somewhere on the pressure side that's letting it bleed off quicker than most (lifter bore clearance). Juat me I'd let it go if above idle it's acceptable & I'm anal/very picky about things
Re: oil pressure issues [Re: RapidRobert] #1428248
05/01/13 12:52 PM
05/01/13 12:52 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Like Robert said - 15psi hot at idle is fine, and 40psi at 2K is fine. What is it's peak pressure hot? Does it go up any more over 2K? What are the clearances on the lower end?
My "first impresion" is it's the lifter bores and nothing to really worry about so long as it can maintain a pressure of 10psi for each 1000 rpm.
Re: oil pressure issues [Re: moper] #1428249
05/02/13 10:48 AM
05/02/13 10:48 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
How about this plug behind the oil filter plate (missing in this pic)?
Re: oil pressure issues [Re: Mapandjlp] #1428250
05/02/13 06:47 PM
05/02/13 06:47 PM
Champion City
Champion City
Ok, Think I got it figured out. I am missing one gallery plug. It's the one in the #5 main saddle.
Does anyone know the part number to it? My Goggle search came up empty.
Re: oil pressure issues [Re: The Sphinx] #1428251
05/02/13 08:35 PM
05/02/13 08:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Hardware store part.
Re: oil pressure issues [Re: The Sphinx] #1428252
05/02/13 09:03 PM
05/02/13 09:03 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Hopefully you've caught your problem.
I had a similar issue rebuilding a 340 years ago with about the same symptoms you are talking about. It turned out that the factory had enlarged the lifter bores over the stock bore size. There were actually factory Mopar oversized lifters available to solve the problem.
Re: oil pressure issues [Re: stumpy] #1428253
05/02/13 09:51 PM
05/02/13 09:51 PM
Champion City
Champion City
What does it look like? Any pics or dimensions? It sounds like it's a press in plug
Re: oil pressure issues [Re: The Sphinx] #1428254
05/02/13 09:57 PM
05/02/13 09:57 PM
If you mean the mini plug that's driven in the oil passage that's next to the #5 main cap pass side bolt up into the vertical passage so the 2 in/out horizontle oil galleries to/from the oil filter are blocked off/seperated from each other I would not think it would cause a psi loss. It only (but critically) forces the oil to make a right turn from the vertical passage & flow out horizontally to the filter then horizontally from the filter back to the vertical passage then up a bit to the main pass horizontle oil gallery. It's a common size mini plug & MP carries it as would your parts house. EDIT maybe the restriction of the filter DOES keep the oil from draining back as I've never been without the plug. Since it's a must have I'd install it at the right depth & we just might get lucky & that be it
