Air operated throttle stop brand, help.
#1427893
04/29/13 11:43 PM
04/29/13 11:43 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
I'm trying to find out who makes the air controlled throttle stop cylinder on my race car, it has "Hardcore racing product" decal on it but I haven't found anything on line that looks like this one. I need to buy the ball stud fitting that goes on the carb. linkage for this to hook to, I hope the picture works well enough for someone who knows the company that makes this and the contact information on them to help me find out who to buy the parts for it from
Re: Air operated throttle stop brand, help.
[Re: pittsburghracer]
#1427895
04/30/13 12:09 AM
04/30/13 12:09 AM
Cab_Burge
I looked at the link, I didn't find it Thanks for the help anyways I'll try calling them tomorrow and see if they still have that controller for sale and the carb. parts availble. Cab
[Re: Cab_Burge]
#1427896
04/30/13 12:32 AM
04/30/13 12:32 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
When I read Hardcore racing his name came to mind. I don't get National Dragster any more but I think he had a big ad in the back. Last time I read one the whole thing was one big ad. To bad as I used to really enjoy reading it. I finally climbed in my attic and started selling off parts that have been collecting dust for years and I found one of those air systems that came on one of my cars.
[Re: sr4440]
#1427899
04/30/13 02:24 PM
04/30/13 02:24 PM
Cab_Burge
Thanks for the help I will probally end up using the air shifter and throttle controller on this car so I will probally need a spare CO2 bottle also I would have not known of these folks without your help
[Re: Cab_Burge]
#1427900
04/30/13 02:29 PM
04/30/13 02:29 PM
Triple Threat
Renton Washington
The air throttle control is illegal in Pro. Shifter I would definitely use, takes one variable out.
[Re: CHAPPER]
#1427905
05/09/13 12:33 PM
05/09/13 12:33 PM
Triple Threat
Renton Washington
Illegal in which sanctioning body, NHRA or IHRA?? I looked in my Ihra book and can't find anything about it. I don't have an NHRA book. I was planing on putting the one off my old car on my 'new' car this week.
NHRA
[Re: CHAPPER]
#1427906
05/09/13 01:19 PM
05/09/13 01:19 PM
Cab_Burge
A electronically control throttle stop is not allowed in NHRA Pro class or any of the other sportsman classes except the Super classes like Super gas, Super Comp and Super Street. A mechanical throttle stop that is preset before the run are allowed, at least I think they still are
[Re: Cab_Burge]
#1427907
05/09/13 03:30 PM
05/09/13 03:30 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Will not be used as a throttle stop, used to apply throttle.. Will not be electronically contolled, unless they call a 12 volt solenoid an 'electronic'. I was always under the impression that electronically was referring to timers/delays/boxes/etc.
If you like drag racing, support your local track.
[Re: Keith Richards]
#1427909
05/09/13 04:47 PM
05/09/13 04:47 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Cab,FWIW In my opinion those inline stops are not the best. most consistent way to doing what you want. If you want to stay in pro I suggest using one of the many under carb stop out there such as Dedenbear sale, or the EZ plate system. They both work very well. If you want to go run Super Pro get an under carb stop. They are much more consistent in thier operatin and you have more control over closing and more importantly closing rate. That inline style stop is best used as a starting line enhancer for full tree bracket racing than it is as a throttle stop. Just my from experience. I know the car you bought somewhat. Would make a great S/ST with the proper set up in it.
[Re: Cab_Burge]
#1427910
05/09/13 08:00 PM
05/09/13 08:00 PM
CHAPPER
Belpre,Ohio
Now that we all understand what we all are trying to do here,,,EXCUSE ME.
[Re: CHAPPER]
#1427912
05/09/13 09:42 PM
05/09/13 09:42 PM
Cab_Burge
Me no Habla,Nix Verstien, I'm not sure what your trying to say Whats up BTW, I did find a ball stud at one of the local Knecht auto parts stores last week, I should have posted that, sorry for not doing it I did have to grind the stem down a little to make it work, I bought three of them so I can put the other two on different carbs to test on the car later,(you know how it goes when your in a hurry trying to swap carbs at the races, I will loose the nut or washers when I'm in a hurry between rounds ) if I don't sell it first Thanks to all on the help I got the tach hook up and working and I study the delay box instructions a liitle, maybe I'll try using it later this month. I'm taking it out this Saturday but NOT on Mothers Day, I like living with me wife the way she is
