Air operated throttle stop brand, help. #1427893
04/29/13 11:43 PM
04/29/13 11:43 PM
Cab_Burge Offline OP
I'm trying to find out who makes the air controlled throttle stop cylinder on my race car, it has "Hardcore racing product" decal on it but I haven't found anything on line that looks like this one. I need to buy the ball stud fitting that goes on the carb. linkage for this to hook to, I hope the picture works well enough for someone who knows the company that makes this and the contact information on them to help me find out who to buy the parts for it from
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427894
04/29/13 11:51 PM
04/29/13 11:51 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Air operated throttle stop brand, help. [Re: pittsburghracer] #1427895
04/30/13 12:09 AM
04/30/13 12:09 AM
I looked at the link, I didn't find it Thanks for the help anyways I'll try calling them tomorrow and see if they still have that controller for sale and the carb. parts availble. Cab
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427896
04/30/13 12:32 AM
04/30/13 12:32 AM
PA.
"Little"John
"Little"John
PA.
When I read Hardcore racing his name came to mind. I don't get National Dragster any more but I think he had a big ad in the back. Last time I read one the whole thing was one big ad. To bad as I used to really enjoy reading it. I finally climbed in my attic and started selling off parts that have been collecting dust for years and I found one of those air systems that came on one of my cars.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Air operated throttle stop brand, help. [Re: pittsburghracer] #1427897
04/30/13 04:03 AM
04/30/13 04:03 AM
I just looked at Summit site and it looks exactly like a Shiftnoid controller I'm going to try taking the cylinder into town tomorrow and see if one of the local hydraulic shops may have that ball stud I need I'll bet money on Billy Mitchell did sell them at one time with his Hardcore racing decal on them Thanks for the help
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427898
04/30/13 08:19 AM
04/30/13 08:19 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Without Data, you’re just another guy with an opinion.
Re: Air operated throttle stop brand, help. [Re: sr4440] #1427899
04/30/13 02:24 PM
04/30/13 02:24 PM
Thanks for the help I will probally end up using the air shifter and throttle controller on this car so I will probally need a spare CO2 bottle also I would have not known of these folks without your help
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427900
04/30/13 02:29 PM
04/30/13 02:29 PM
Renton Washington
Triple Threat Offline
Renton Washington
The air throttle control is illegal in Pro. Shifter I would definitely use, takes one variable out.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Air operated throttle stop brand, help. [Re: Triple Threat] #1427901
04/30/13 02:38 PM
04/30/13 02:38 PM
Thanks for reminding me, this car is way faster than I thought it would be so I may not be able to run it in Pro I may end up having to run it in Super Pro, basically quitting driving and becoming a electronic box controller programmer again
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427902
04/30/13 04:36 PM
04/30/13 04:36 PM
PA.
"Little"John
"Little"John
PA.
Thanks for reminding me, this car is way faster than I thought it would be so I may not be able to run it in Pro I may end up having to run it in Super Pro, basically quitting driving and beocme a box comtroller programer
Its not as easy as it sounds but if you find yourself winning to much money I could sure help you spend some of it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427903
04/30/13 05:56 PM
04/30/13 05:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the same cyl but I never put it on the car
Re: Air operated throttle stop brand, help. [Re: Triple Threat] #1427904
05/09/13 12:29 PM
05/09/13 12:29 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Illegal in which sanctioning body, NHRA or IHRA?? I looked in my Ihra book and can't find anything about it. I don't have an NHRA book. I was planing on putting the one off my old car on my 'new' car this week.
If you like drag racing, support your local track.
Re: Air operated throttle stop brand, help. [Re: CHAPPER] #1427905
05/09/13 12:33 PM
05/09/13 12:33 PM
Renton Washington
Renton Washington
NHRA
Re: Air operated throttle stop brand, help. [Re: CHAPPER] #1427906
05/09/13 01:19 PM
05/09/13 01:19 PM
A electronically control throttle stop is not allowed in NHRA Pro class or any of the other sportsman classes except the Super classes like Super gas, Super Comp and Super Street. A mechanical throttle stop that is preset before the run are allowed, at least I think they still are
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427907
05/09/13 03:30 PM
05/09/13 03:30 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Will not be used as a throttle stop, used to apply throttle.. Will not be electronically contolled, unless they call a 12 volt solenoid an 'electronic'. I was always under the impression that electronically was referring to timers/delays/boxes/etc.
Re: Air operated throttle stop brand, help. [Re: CHAPPER] #1427908
05/09/13 04:07 PM
05/09/13 04:07 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Cab, Whatever you do with that I suggest you keep the shaft well oiled with teflon or wd40 spray as they can change there operation quickly if not used for a race or two and effect car / ET.
Keith
Re: Air operated throttle stop brand, help. [Re: Keith Richards] #1427909
05/09/13 04:47 PM
05/09/13 04:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cab,FWIW In my opinion those inline stops are not the best. most consistent way to doing what you want. If you want to stay in pro I suggest using one of the many under carb stop out there such as Dedenbear sale, or the EZ plate system. They both work very well. If you want to go run Super Pro get an under carb stop. They are much more consistent in thier operatin and you have more control over closing and more importantly closing rate.
That inline style stop is best used as a starting line enhancer for full tree bracket racing than it is as a throttle stop. Just my from experience.
I know the car you bought somewhat. Would make a great S/ST with the proper set up in it.
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427910
05/09/13 08:00 PM
05/09/13 08:00 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Now that we all understand what we all are trying to do here,,,EXCUSE ME.
Re: Air operated throttle stop brand, help. [Re: Cab_Burge] #1427911
05/09/13 09:11 PM
05/09/13 09:11 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Is this all you are looking for? Not sure if this would help you.
http://www.mcmaster.com/#ball-studs/=moiudv
Re: Air operated throttle stop brand, help. [Re: CHAPPER] #1427912
05/09/13 09:42 PM
05/09/13 09:42 PM
Me no Habla,Nix Verstien, I'm not sure what your trying to say Whats up BTW, I did find a ball stud at one of the local Knecht auto parts stores last week, I should have posted that, sorry for not doing it I did have to grind the stem down a little to make it work, I bought three of them so I can put the other two on different carbs to test on the car later,(you know how it goes when your in a hurry trying to swap carbs at the races, I will loose the nut or washers when I'm in a hurry between rounds ) if I don't sell it first Thanks to all on the help I got the tach hook up and working and I study the delay box instructions a liitle, maybe I'll try using it later this month. I'm taking it out this Saturday but NOT on Mothers Day, I like living with me wife the way she is
