How much fluid for a 904, converter, cooler, etc.
#1427293
04/29/13 12:20 AM
04/29/13 12:20 AM
Posts: 3,426 Toronto
mshred
Toronto
I need to order some fluid from my mechanic for my 904. This is a fresh build, never ran before, with a summit deep pan on it, a trans cooler with 3/8" cooler lines, and an 8" converter. I have no idea how much fluid to order, and want to make sure I have enough when I go to fire this thing up for the first time since I will be worrying about breaking in the flat tappet cam and don't want to be worrying about running way too low or high on trans fluid...I know everyone's amount they use may be different, but just trying to get an idea here so im in the ballpark.
Thanks! Matthew
Re: How much fluid for a 904, converter, cooler, etc.
[Re: mshred]
#1427294
04/29/13 12:38 AM
04/29/13 12:38 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Like you said every car is not the same, did you put any in the converter? converter size? I would start with 7 and have a few at the ready
[Re: mshred]
#1427295
04/29/13 12:44 AM
04/29/13 12:44 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Thanks! Matthew
Bone dry like yours...same pan...new lines..new cooler..8 in converter,,,my 904 took 12 qts.
Just started up a new engine/904 combo..with MP deep pan put 6 qts in it...fired engine in neutral..dumped another 4-5 qts in it while engine was broke it.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: mshred]
#1427296
04/29/13 01:45 AM
04/29/13 01:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would throw in 8-10 qts from a bone dry system... I expect you will be breaking in the cam with the trans in park... with the trans in park it doesnt pump the fluid so if you check the level it would be wrong.. it will have plenty in it to lube the parts and when you get done with the cam put it in N after you run it through the gears then when in N check the level and add to full ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Just-a-dart]
#1427297
04/30/13 12:05 AM
04/30/13 12:05 AM
mshred
Toronto
I put a wee bit in the converter, but I had to install the converter and trans from under the car with the engine already in since I had a converter issue, so I couldn't put much in there in case it spilt out.
7 quarts or liters?
[Re: 70AARcuda]
#1427298
04/30/13 12:06 AM
04/30/13 12:06 AM
mshred
Toronto
Thanks! Matthew
Happy Birthday Tony!
I am thinking of grabbing 12 quarts just to be safe, and whatever I don't end up using I have leftover for the first fluid change
[Re: MR_P_BODY]
#1427299
04/30/13 12:07 AM
04/30/13 12:07 AM
mshred
Toronto
Mr. P, can I break in the cam with the trans in neutral? I was aware of the pump not building pressure in park with the torqueflites, and because my trans is going to be fired up bone dry and I would like to have the motor up to break in rpms in about 30 seconds or so, I was going to start it and run it in neutral so fluid is pumping through and everything is getting lubed up.
Or am I wrong in my thinking?
[Re: mshred]
#1427300
04/30/13 12:14 AM
04/30/13 12:14 AM
MR_P_BODY
Thats fine... block the tire so it doesnt roll ![](/ubbthreads/images/graemlins/wave.gif)
[Re: cagebob1]
#1427303
04/30/13 12:42 AM
04/30/13 12:42 AM
mshred
Toronto
better yet, jack the rear up so the wheels are free to turn. if clutch clearances are even a little too tight you will burn them from lack of lube.
in gear you mean? or in neutral?
[Re: mshred]
#1427304
04/30/13 08:21 AM
04/30/13 08:21 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
On jack stands, in neutral. ![](/ubbthreads/images/graemlins/thumbs.gif)
