How much fluid for a 904, converter, cooler, etc. #1427293
04/29/13 12:20 AM
04/29/13 12:20 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I need to order some fluid from my mechanic for my 904. This is a fresh build, never ran before, with a summit deep pan on it, a trans cooler with 3/8" cooler lines, and an 8" converter. I have no idea how much fluid to order, and want to make sure I have enough when I go to fire this thing up for the first time since I will be worrying about breaking in the flat tappet cam and don't want to be worrying about running way too low or high on trans fluid...I know everyone's amount they use may be different, but just trying to get an idea here so im in the ballpark.
Thanks!
Matthew
Re: How much fluid for a 904, converter, cooler, etc. [Re: mshred] #1427294
04/29/13 12:38 AM
04/29/13 12:38 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Like you said every car is not the same, did you put any in the converter? converter size? I would start with 7 and have a few at the ready
Re: How much fluid for a 904, converter, cooler, etc. [Re: mshred] #1427295
04/29/13 12:44 AM
04/29/13 12:44 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Thanks!
Matthew
Bone dry like yours...same pan...new lines..new cooler..8 in converter,,,my 904 took 12 qts.
Just started up a new engine/904 combo..with MP deep pan put 6 qts in it...fired engine in neutral..dumped another 4-5 qts in it while engine was broke it.
Tony
70 AARCuda Vitamin C
Re: How much fluid for a 904, converter, cooler, etc. [Re: mshred] #1427296
04/29/13 01:45 AM
04/29/13 01:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would throw in 8-10 qts from a bone dry system...
I expect you will be breaking in the cam with the trans
in park... with the trans in park it doesnt pump the
fluid so if you check the level it would be wrong..
it will have plenty in it to lube the parts and when
you get done with the cam put it in N after you run
it through the gears then when in N check the level
and add to full
Re: How much fluid for a 904, converter, cooler, etc. [Re: Just-a-dart] #1427297
04/30/13 12:05 AM
04/30/13 12:05 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I put a wee bit in the converter, but I had to install the converter and trans from under the car with the engine already in since I had a converter issue, so I couldn't put much in there in case it spilt out.
7 quarts or liters?
Re: How much fluid for a 904, converter, cooler, etc. [Re: 70AARcuda] #1427298
04/30/13 12:06 AM
04/30/13 12:06 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks!
Matthew
Happy Birthday Tony!
I am thinking of grabbing 12 quarts just to be safe, and whatever I don't end up using I have leftover for the first fluid change
Re: How much fluid for a 904, converter, cooler, etc. [Re: MR_P_BODY] #1427299
04/30/13 12:07 AM
04/30/13 12:07 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
and add to full
Mr. P, can I break in the cam with the trans in neutral? I was aware of the pump not building pressure in park with the torqueflites, and because my trans is going to be fired up bone dry and I would like to have the motor up to break in rpms in about 30 seconds or so, I was going to start it and run it in neutral so fluid is pumping through and everything is getting lubed up.
Or am I wrong in my thinking?
Re: How much fluid for a 904, converter, cooler, etc. [Re: mshred] #1427300
04/30/13 12:14 AM
04/30/13 12:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
and add to full
Thats fine... block the tire so it doesnt roll
Re: How much fluid for a 904, converter, cooler, etc. [Re: MR_P_BODY] #1427301
04/30/13 12:30 AM
04/30/13 12:30 AM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
better yet, jack the rear up so the wheels are free to turn. if clutch clearances are even a little too tight you will burn them from lack of lube.
Re: How much fluid for a 904, converter, cooler, etc. [Re: cagebob1] #1427302
04/30/13 12:34 AM
04/30/13 12:34 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yup...up on jack stands..
Tony
Re: How much fluid for a 904, converter, cooler, etc. [Re: cagebob1] #1427303
04/30/13 12:42 AM
04/30/13 12:42 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
in gear you mean? or in neutral?
Re: How much fluid for a 904, converter, cooler, etc. [Re: mshred] #1427304
04/30/13 08:21 AM
04/30/13 08:21 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
On jack stands, in neutral.
