Page 3 of 6 1 2 3 4 5 6
Re: more xr1 problems [Re: fishy340] #1427035
04/29/13 10:26 PM
04/29/13 10:26 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Guys, there's only 2 words that someone bringing a product to market that is as complicated as a new block should use to the fullest. Those 2 words are: QUALITY CONTROL!!!! Every one of the problems discussed in all the posts about XR1 and XR2 could have been found and corrected with a viable QC program. It tickles me when some try to justify his problems by saying how complicated it is. Guys look around that's a piddling little machining problem.
Re: more xr1 problems [Re: Blucuda413] #1427036
04/29/13 10:37 PM
04/29/13 10:37 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i wonder why it wasn't applied.
Re: more xr1 problems [Re: Blucuda413] #1427037
04/29/13 10:38 PM
04/29/13 10:38 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I've had problems with just about every aftermarket block I've used. Not justifying just saying.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: more xr1 problems [Re: sixpackbee] #1427038
04/29/13 10:46 PM
04/29/13 10:46 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
We had more quality control in a greasy 50+ year old steel mill then this. If i put out work like that rebuilding a gear case I would be on the street in about 5 minutes. Its a NEW block in a machine shop guys. Take some pride in your work and get it right.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: more xr1 problems [Re: MR_P_BODY] #1427039
04/29/13 11:25 PM
04/29/13 11:25 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ok... the drift I got so far is that this block will
take a W series head... is it a 59* or 48* block
and whats the standard deck height... is it a 4 bolt
main, whats the cam tunnel bearing size... sorry
to ask all the questions with you having your problems
with it
....a little insight Mr. P.
http://www.hughesengines.com/TechArticles/1ritterracingsmallblocks.php
Re: more xr1 problems [Re: pittsburghracer] #1427040
04/29/13 11:49 PM
04/29/13 11:49 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
it seem the quality of the casting is fine now. but all the machine work sucks . kent will not listen to me or anybody else . I think if kent put one of his motors together him self he would see what all of us are going through. and he would find a better machine shop..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: more xr1 problems [Re: J_BODY] #1427041
04/30/13 12:01 AM
04/30/13 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: more xr1 problems [Re: MR_P_BODY] #1427042
04/30/13 12:16 AM
04/30/13 12:16 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...and there was this teaser:
https://board.moparts.org/ubbthreads/showflat.php?Number=7108328
Seems there was a member with his hands on one, but I wasn't paying too much attention to the post as it was way out of my league. Right now I might have been dumb enough to buy one!
Re: more xr1 problems [Re: J_BODY] #1427043
04/30/13 12:32 AM
04/30/13 12:32 AM
Arizona
Chris'sBarracuda Offline
Arizona
Were those top head bolt holes in the wrong place like guys are describing..???
Chris..
Re: more xr1 problems [Re: Chris'sBarracuda] #1427044
04/30/13 06:50 PM
04/30/13 06:50 PM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
I can't speak about everyone's XR1 issues but I do know some things about the XR1/W7 engine. That block was initially purchased from Kent with no head studs and lifter bores machined in it. Reason being, it was originally going to be used with P5 heads. Later on they decided to run the W7's to go heads-up class racing. (Mainly X275 and NMCA Xtreme Street and Street Outlaw classes.) The block was then sent out to be machined for head studs and lifter bores. In the process of drilling the head studs, they were drilled in the wrong location and they had to be plugged and re-drilled again. Water was basically coming up through the head studs and leaking while on the dyno. Being a former manufacturer rep I can sympathize when certain details are left unknown and I just wanted to set the record straight on this particular situation. Thanks!
Re: more xr1 problems [Re: Dave W] #1427045
05/01/13 12:12 AM
05/01/13 12:12 AM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
If only Maskin(DART) would release Mopar blocks all the problems would be solved..
Re: more xr1 problems [Re: CRIKEY] #1427046
05/01/13 12:34 AM
05/01/13 12:34 AM
PA.
"Little"John
"Little"John
PA.
Just think if Keith Black offered a small block. HINT HINT.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: more xr1 problems [Re: Dave W] #1427047
05/01/13 12:35 AM
05/01/13 12:35 AM
bean town ....Ca
W
W
bean town ....Ca
I hope he can get it together. were the holes put in the wrong place by kents machine shop or some one else.
Re: more xr1 problems [Re: WHITEDART] #1427048
05/01/13 12:41 AM
05/01/13 12:41 AM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
someone else...
Re: more xr1 problems [Re: Dave W] #1427049
05/01/13 12:55 AM
05/01/13 12:55 AM
bean town ....Ca
W
W
bean town ....Ca
someone else...
that sucks......... when you move past AZ. AND keep driving to so cal not so hot here
Re: more xr1 problems [Re: WHITEDART] #1427050
05/01/13 08:56 AM
05/01/13 08:56 AM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
someone else...
Wish I could, we can get a lot more ''bang for the buck'' house wise in AZ.
Re: more xr1 problems [Re: Dave W] #1427051
05/01/13 09:42 AM
05/01/13 09:42 AM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
Do you know where you're going to end up in AZ?
Re: more xr1 problems [Re: WHITEDART] #1427052
05/01/13 09:54 AM
05/01/13 09:54 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Why not just use the proven/bulletproof R5 block? An engine in the 420-430 CI range can be built easily.
I'm going to look at a complete R5/P7 next week, and that will be my plan if I end up getting it.
Re: more xr1 problems [Re: LSP] #1427053
05/01/13 11:18 AM
05/01/13 11:18 AM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
Initially that was the route I was going to take. I even ordered a crank from Winberg to go up to 400 cubes. After waiting 6 months for a one-off crank and with no firm deadline on when it would be done, I decided to take my money and go with the XR2 option instead. I feel like the XR2/P7 engine combo can be a viable answer to the small block guys who are craving more hp. Take a look at all the SB2 high horsepower combinations... no big secret that the heads are the key. I have had conversations with a few different well known head porters and they all agree the P7's have more potential than the SB2's. Unfortunately for us small block Mopar guys, there is no known proven recipe to use these heads in a 400+ cu.in. engine.
Re: more xr1 problems [Re: Dave W] #1427054
05/01/13 01:39 PM
05/01/13 01:39 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
The exhaust guide could be offset a bit to get a bigger intake valve in to give it some air, the cam would be a matter of trying a few. I think a R5/P7 in the NMCA N/A 10.5 class would be a real competitive combo in a good car.
