Removing windshield #1426969
04/28/13 07:28 PM
04/28/13 07:28 PM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
85 Van I am parting/cutting up. glass is going in the trash anyways but I would like to avoid busting this thing up and making a huge mess.
Re: Removing windshield [Re: 135sohc] #1426970
04/28/13 07:50 PM
04/28/13 07:50 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Not glued in, IIRC. Just cut the gasket.
Never had a van, so not sure.
It takes gasoline to interest me.
Re: Removing windshield [Re: VL21] #1426971
04/28/13 07:59 PM
04/28/13 07:59 PM
scratchnfotraction Offline
remove the lock strip and use a 10" butcher knife pressed against the glass slicing into the rubber all the way around it.
push glass out and remove the 1/2 of gasket that is left.
very ez and simple unless you need to re-use the gasket.
