Last year for 727s in trucks/vans? #1426845
04/28/13 06:11 PM
04/28/13 06:11 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
From what I can tell by searching the tech archives and the Google search at the top of the page, '78 was the last year for regular production 727s. There is mention of them in fleet vehicles and trucks after '78. Any way to tell other than dropping the pan to check the valve body or pulling the trans. to look at the input shaft? Reason I ask is I'm headed to a pull-a-part Saturday to try and find one for parts for the Charger.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Last year for 727s in trucks/vans? [Re: I_bleed_MOPAR] #1426846
04/28/13 06:45 PM
04/28/13 06:45 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you're referring to non-lockups, I do know that 89 still had non lockup 727's in 4x4's at least. Depends on what parts you're after I guess.
Re: Last year for 727s in trucks/vans? [Re: buildanother] #1426847
04/28/13 07:43 PM
04/28/13 07:43 PM
scratchnfotraction Offline
I just got a 85 727 non lock up from a JY.
I have not confirmed the pan rail #s on it as anything can be replaced/rebuilt as needed now days.
my 85 truck came with an 85 727 lock up trans,the last 2 replacement I have used have been 85 non lock up 727.
Re: Last year for 727s in trucks/vans? [Re: I_bleed_MOPAR] #1426848
04/28/13 07:47 PM
04/28/13 07:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What do you mean by "regular production"? The 727 was renamed 36RH in the early nineties and was still available in '99.
Re: Last year for 727s in trucks/vans? [Re: I_bleed_MOPAR] #1426849
04/28/13 09:04 PM
04/28/13 09:04 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Don't waste your time pulling one at the yard, just come buy one from me.
Re: Last year for 727s in trucks/vans? [Re: RV2] #1426850
04/28/13 09:15 PM
04/28/13 09:15 PM
Buford, GA
Buford, GA
John, I was referring to non lock-up 727s. Wrong term, I guess.
Ralph, I completely forgot about you down there. You've got a PM.
Tim
'71 Charger 383/727
Re: Last year for 727s in trucks/vans? *DELETED* [Re: John_Kunkel] #1426851
04/29/13 12:26 AM
04/29/13 12:26 AM
crisfield, maryland 21817
8
82ramIndy493 Offline
Post deleted by 82ramIndy493
Re: Last year for 727s in trucks/vans? [Re: 82ramIndy493] #1426852
04/29/13 02:12 PM
04/29/13 02:12 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
These were the overdrive models known as 518's and not 727's.
A 518 is a 46RH
Re: Last year for 727s in trucks/vans? [Re: 82ramIndy493] #1426853
04/29/13 02:54 PM
04/29/13 02:54 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
you would be incorrect.
36RH is the later Mopar designation terminology for a 727
32RH is 904 based case design
A518 became a 46RH then 46RE ( both of which are an OD btw )
4 = # of forward speeds
6 = HD
R = rear wheel drive
H = hydraulic governor ( E = electronic governor)
To answer the op, I believe it was approx real late 90's or early 2000's and even then I believe it was only only in B vans . Best I can remember all pickups had gone to the A518 OD trans by then
Re: Last year for 727s in trucks/vans? *DELETED* *DELETED* [Re: T2R9] #1426854
04/29/13 08:21 PM
04/29/13 08:21 PM
8
Re: Last year for 727s in trucks/vans? *DELETED* *DELETED* [Re: gtx6970] #1426855
04/29/13 08:32 PM
04/29/13 08:32 PM
8
Re: Last year for 727s in trucks/vans? [Re: 82ramIndy493] #1426856
04/30/13 06:22 AM
04/30/13 06:22 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I know all of this and I have not seen a single 727 in anything Dodge makes past 93.
http://www.car-part.com
Just did a search for a '99 van with a 3 speed, there is several less than an hours drive from my location.
Just for the heck of it I logged into Mopars dealer connect and at least for 1999 the 32RH is listed for ram vans with a 5.2 or 5.9 light duty.
1997 is the last year I see a 36RH in a van with a 5.9
Re: Last year for 727s in trucks/vans? [Re: 82ramIndy493] #1426857
04/30/13 04:45 PM
04/30/13 04:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I was exactly correct in what I was saying. If you read what I was quoting it says that it was renamed a 36RH in the nineties and was still available in 1999. This is incorrect. The new style dodge truck came out in 94 and it only came with the 518 or 46RH or whatever they want to call it. But it was not a 727.
Nobody said it had to be in a truck, I merely stated the 727 (renamed 36RH) was available as late as '99 but, yes, only in vans.
Re: Last year for 727s in trucks/vans? [Re: John_Kunkel] #1426858
04/30/13 07:49 PM
04/30/13 07:49 PM
8
Not a problem! Only stated that I have never seen a 727 or 36RH or whatever they want to call it, in anything past 89 myself. I have had a salvage yard here for many years and everything that comes here in the 90's up has had 518's or 46RH,RE's in them including vans. It really doesn't matter to me though. If they built 727's all the way to 2013 instead of the overdrives it wouldn't break my heart.
