engine builders whats max clearence on mains #1426362
04/27/13 05:28 PM
04/27/13 05:28 PM
BigFish69 Offline OP
What would be max main bearing clearence on rb race motor I have .00375 to .004 on the mains to loose ?
Re: engine builders whats max clearence on mains [Re: BigFish69] #1426363
04/27/13 06:28 PM
04/27/13 06:28 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I wouldn't like 4 ... but maybe it would be OK using STRAIGHT-50 weight oil ..
Re: engine builders whats max clearence on mains [Re: BigFish69] #1426364
04/27/13 06:31 PM
04/27/13 06:31 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
If that's with dial bore gauge and you are sure about the number run it. it will be fine.
Re: engine builders whats max clearence on mains [Re: BigFish69] #1426365
04/27/13 07:26 PM
04/27/13 07:26 PM
Delray beach, Florida
P
Performance Only Offline
P
I'll answer the question with a question. How did you get to that clearance? Either the crank is undersize or the main housings are bigger than spec. Before i'd say run it, i'd want to know which it is and how much power is the engine going to make. If the housing bores are out of spec, fix them. that's your bearing crush. If those are okay and it's just the crank being on the small side i'd say have at it on a serious combo.
machine shop owner and engine builder
Re: engine builders whats max clearence on mains [Re: Performance Only] #1426366
04/27/13 08:22 PM
04/27/13 08:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
For what its worth my line hone was off so we set it at the tight end of the crank bore housing dimension. Mains ended up at .0025". I wanted more so I switched bearing manufactures(no info in front of me as I'm overseas) and got.0028"-.0029". Even though the rod journals were .001" undersize I still only had .0018" on the rods. Had BME resize the rods and ended up with .004" rod clearance. I didn't like the oil pressure so I switched the rod bearings to .001" under, rods now at .003". That really didn't do much for pressure. I ended up tightening the oil pump relief valve spring. Upped the pressure from 45 to 60 at 7000. I probably should have left the clearnce at .004". It's really about oil flow not pressure.
Doug
Re: engine builders whats max clearence on mains [Re: BigFish69] #1426367
04/27/13 09:02 PM
04/27/13 09:02 PM
MI
RickRoss Offline
RickRoss  Offline
MI
U need a small block
Re: engine builders whats max clearence on mains [Re: BigFish69] #1426368
04/27/13 09:45 PM
04/27/13 09:45 PM
Not in my opinion, as long as there is no other problems. I have bought used fuel crank that where not cracked and used them with those clearances on my own pump gas street motors with no real problems to speak of( 18 lbs oil pressure with hot (190+ F)5W20 Valvoline at 800 RPM idling in gear, 65 lbs at 6500 RPM with the same oil temps three minutes later
