Re: Oil Pressure light malfunction
[Re: frank]
#1426344
04/27/13 06:50 PM
04/27/13 06:50 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
The pressure switch grounds the wire when there is no oil pressure.
Ground the wire manually with the switch disconnected and see if your light comes on. Should be off when you unground it.
It that works ok then your switch is bad.
