rough runner #1425876
04/26/13 06:45 PM
04/26/13 06:45 PM
Sunny San Diego
1sprinter Offline OP
Sunny San Diego
Ok lads, I think I f'd somethin' up here. I recently installed my 69 440hp with a brand new engine harness. I wired a summit ignition and coil into a msd dist. with new 8.0 street fire wires. I mixed up the plug wires. The motor bounced around pretty good, backfired, popped, and a nice little flame burst through the carb. I sorted out the plug wires now the engine runs like I'm missing a cylinder. I pulled all the plugs and they are all black. I'm also getting a good amount of white smoke which is I'm assuming unburned fuel. It starts up and idles ok but rough. What do you think I ruined? I'm workin on it now tryin' anything to smooth it out. 2:30 pm. pacific time.
Re: rough runner [Re: 1sprinter] #1425877
04/26/13 07:38 PM
04/26/13 07:38 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
running a holley? a backfire can wreck the power valve. when that happens, it won't run right
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: rough runner [Re: VincentVega] #1425878
04/26/13 07:41 PM
04/26/13 07:41 PM
Sunny San Diego
Sunny San Diego
thermoquad 850
Re: rough runner [Re: 1sprinter] #1425879
04/26/13 07:46 PM
04/26/13 07:46 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
what did you do about the fouled plugs? at the very least, you need to clean them up
Re: rough runner [Re: 1sprinter] #1425880
04/26/13 08:51 PM
04/26/13 08:51 PM
Please tell me this ain't a new engine/cam breakin. I'd check the wires being especially carefull with #5 & #7. Clean the plugs/check reluctor gap/set initial. White smoke is either ALOT of condensation or a coolant leak.
Re: rough runner [Re: VincentVega] #1425881
04/26/13 08:53 PM
04/26/13 08:53 PM
Sunny San Diego
Sunny San Diego
Problem solved. I guess when it popped it created a leak with the gasket under the carb. I replaced and the thing is bitchen again. i always look to deep into this stuff. The answer is usually in front of your nose and pretty cheap. Thanks Vinnie. Say hi to Marcelus.
Re: rough runner [Re: RapidRobert] #1425882
04/26/13 08:59 PM
04/26/13 08:59 PM
Sunny San Diego
Sunny San Diego
Nope. Engine was broken in a the speed shop down the street. funny thing when I cracked open the dist. the metal ring with the fins (reluctor?)was totally rusted up. Cleaning that helped as well. Thanks for the note. TT
