06 300 Struts? #1425505
04/25/13 09:01 PM
04/25/13 09:01 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
So how difficult are the front struts to replace if you buy the loaded units? The FSM isn't really too clear on the procedure.
Mike
Re: 06 300 Struts? [Re: 1E2C] #1425506
04/26/13 08:11 AM
04/26/13 08:11 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Typically if you buy Quick struts they are easy to change.I did some on earlier Caravans etc.3 nuts on top,some have a cover over them.Then usually 2 bolts and possibly a brake line attached.Some the sway link and almost all the tie rod end.I can usually R&R a set in less than 1/2 hour on a rack.Rocky
Chrysler Firepower
Re: 06 300 Struts? [Re: therocks] #1425507
04/26/13 07:29 PM
04/26/13 07:29 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
That doesn't sound near as bad as the manual sounds.
Re: 06 300 Struts? [Re: 1E2C] #1425508
04/26/13 11:48 PM
04/26/13 11:48 PM
dogdays Offline
dogdays  Offline
The 300 is a different beast. Suspension is Mercedes Benz derived. I seriously doubt it'll be that easy. Trust the service manual.
R.
