Purple shaft Camshaft I.D.? #1425424
04/25/13 03:52 PM
04/25/13 03:52 PM
Badge Offline OP
Badge  Offline OP
New guy working on a small block 360. I removed the intake and heads. I see that the camshaft has some purple color on the shaft up toward the front of the motor. I also see a orange marking toward the back. Please take a look at the linked pictures and tell me if this is a mopar purple shaft. Thanks
http://i17.photobucket.com/albums/b65/Badge01/005-1_zpsa9ad6f00.jpg
http://i17.photobucket.com/albums/b65/Badge01/004-3_zpseceff38b.jpg
Re: Purple shaft Camshaft I.D.? [Re: Badge] #1425425
04/25/13 05:15 PM
04/25/13 05:15 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
not sure if they are all like mine, but my purple cam from MP had a lot more purple than the one you have pictured..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Purple shaft Camshaft I.D.? [Re: abodyjoe] #1425426
04/25/13 05:28 PM
04/25/13 05:28 PM
Badge Offline OP
Badge  Offline OP
I guess my next step is to put a dial indicator on it and measure lift at the lifter.
Re: Purple shaft Camshaft I.D.? [Re: Badge] #1425427
04/25/13 10:07 PM
04/25/13 10:07 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thats the only way to find out what it is.. Make sure you multiply the reading by 1.5.
I am truckless..
Re: Purple shaft Camshaft I.D.? [Re: 340SHORTY] #1425428
04/26/13 05:26 PM
04/26/13 05:26 PM
Badge Offline OP
Badge  Offline OP
I am glad I measured it. Looks to be .480 lift on both intake and exhaust ( .320 net ) And, it appears to have stock valve springs
