small block dist. ?? #1425086
04/24/13 09:16 PM
04/24/13 09:16 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
What happens when you take the vacuum advance off of a mopar style dist. Would it become a mech. advance dist?
thanks for any help
Re: small block dist. ?? [Re: kams] #1425087
04/24/13 09:55 PM
04/24/13 09:55 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
it already has mechanical advance
Re: small block dist. ?? [Re: kams] #1425088
04/24/13 11:44 PM
04/24/13 11:44 PM
I would suggest that only for converting a dist to race only (or a very serious street app). To keep the plates stabilized when the vac adv is removed drill 2 holes vertical in the appropriate place between the 2 plates then bolt them together with a small bolt/nut & use a spacer on the bolt shank inbetween the 2 plates so the plates do not tilt/remain parallel when you tighten the nut/bolt. EDIT that'd also be an opportunity to get the rotor phasing dead on. Before you remove the can pump it up gradually till the rotor tip is centered then drill the plates at that point & pin em then remove the can/reset the reluctor gap
