Dye the carpet ?? #1425068
04/24/13 08:47 PM
04/24/13 08:47 PM
S.e. lower MIch..
66droptop Offline OP
S.e. lower MIch..
1966 coronet convertable...I am fixing the seats so I want to get the carpet back to black.The carpet was replaced in 1991,still looks great but it has faded in areas.What can I use to get the carpet black and do I have to take the carpet out of the car?
Re: Dye the carpet ?? [Re: 66droptop] #1425069
04/24/13 09:07 PM
04/24/13 09:07 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Clean it and dye it!
Re: Dye the carpet ?? [Re: moparpollack] #1425070
04/24/13 09:49 PM
04/24/13 09:49 PM
mo
Mr. Mojo Risen Offline
Justa 'member'
Justa 'member'
mo
ya hes right go buy the black ritz dye from the grocery store and mix it in a spray bottle with water. it looks brand new when your done
Re: Dye the carpet ?? [Re: Mr. Mojo Risen] #1425071
04/25/13 09:41 AM
04/25/13 09:41 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I installed new carpet but didn't have enough for the sides of console . . . so cleaned the carpet on the console, and painted with Vinyl & Fabric paint. Looks perfect !!! . . . good luck !
Cheers
Mark
Re: Dye the carpet ?? [Re: a12rag] #1425072
04/30/13 09:18 PM
04/30/13 09:18 PM
S.e. lower MIch..
S.e. lower MIch..
Will sparying from a bottle cause much overspray.I would like to be able to keep the carpet in the car..
Re: Dye the carpet ?? [Re: 66droptop] #1425073
05/01/13 12:22 AM
05/01/13 12:22 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Buy a cheap pressure sprayer with an adjustable pattern and have at it. I think we need to see more pics of you car!
Re: Dye the carpet ?? [Re: Jeremiah] #1425074
05/01/13 02:05 AM
05/01/13 02:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I tried dying a carpet once with RIT. Apparently synthetic fibers that the carpet I was working with would not accept dye. I ended up spraying it with SEM (which is a flexible paint, not a dye).
Re: Dye the carpet ?? [Re: DaytonaTurbo] #1425075
05/30/13 04:59 PM
05/30/13 04:59 PM
S.e. lower MIch..
S.e. lower MIch..
Took 3 applications from a small spray bottle and the carpet is all one shade of nice black....
Thanx.
