Re: Eastwood sound deadening mats
[Re: nomore65BelvJim]
#1424960
04/24/13 03:56 PM
04/24/13 03:56 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
The cheapest way that I know of is to use Modified bitumen rolled roofing and a layer of bubble foil insulation. Find a commercial roofer and ask to buy some scraps or cut-off ends from a roll. Or buy a whole 39"x 33' roll at a commercial roofing wholesaler for about $80. The bubble insul is about $14 at Menards. I did this on my 67 Olds 442, and was amazed at how effective it was. Much quieter and cooler than before. I didn't even cover the hump or the doors. I just made sure to get the firewall really well and the floor pans. Since it is a convert, I din't know if I would notice any sound deadening because of wind noise, but it was very noticable.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: screamindriver]
#1424963
04/25/13 09:39 AM
04/25/13 09:39 AM
Posts: 2,919 Calgary, Alberta Canada
a12rag
I did the "Fat Mat" stuff off ebay, covering the complete floor, hump, firewall, rear wheel well part that is in passenger compartment, and the package tray . . . WOW !!! Can certainly tell the car is quieter inside, and you can barely hear the wonderfull exhaust sound . . . so, I say it is worth the effort to install and the little bit (ok, maybe more than a little) of added weight !!!
I also noticed the heat was way down too !!! I had run the engine without the mat installed and noticed how warm the tranny tunnel got - nothing now with the mat installed !!!
I think for the money, the fat mat stuff, is worth it !! As far as it melting or coming unglued . . . can't say as I have gotten things that warm !!!
Cheers
Mark
[Re: a12rag]
#1424964
04/25/13 11:41 AM
04/25/13 11:41 AM
Posts: 5,160 Texas
dannysbee
Texas
I know some here are weight consious. A good place to look for lightweight sound deadining products is the aircraft industry. Costs more but in some cases definitely worth it. Just some food for thought.
Getting old just means you were smarter than some and luckier than others.
[Re: Coronet-R/T-Rag]
#1424965
04/26/13 01:29 AM
04/26/13 01:29 AM
Posts: 752 AZ - The "dry heat" state
71autoxr
2 boxes in my dart convertible. I did inside doors, floors firewall, inner rear quarters, basically everywhere i could. No problems melting. Im in az, and been out in 110F with the asphault temps likely in the 150s. AC kept the car reasonable comfortable. As far as sound deadener quality, worth the weight. Mine is a cruiser so i wanted comfort over power. Ive got heat shields on the mufflers and so far no melting of the insualtion. Stuff is easy to work with, and makes a world of difference. I wouldnt definately do it again.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
[Re: Hemi_Joel]
#1424967
04/26/13 02:41 AM
04/26/13 02:41 AM
Posts: 2,782 USA
JoesMopar
USA
I have a roll of that stuff and was thinking of using it as well.
Would it be "ok" to spray undercoating onto the floor pans to not only seal them good but reduce noise as well? Wasn't sure about the fire risk.
[Re: jlatessa]
#1424971
04/26/13 06:26 PM
04/26/13 06:26 PM
Posts: 509 Middle River, MD
Mapandjlp
Middle River, MD
Looks good, what adhesive did you use/
Thanks, Joe
If you're asking me, I didn't use adhesive. Just laid it out on the floor and put the carpet over top. It stays in place pretty well as it's a pretty non-slick material. IIRC, it's made from recycled tires.
#1424972
04/28/13 06:38 AM
04/28/13 06:38 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
My unused Eastwood 36 sq ft mat kit is for sale. For you only a special deal - half price. Waaay too heavy. You pay the freight. No refunds.
