Braided Stainless Steel Brake lines vs Rubber? #142477
10/27/08 10:23 PM
10/27/08 10:23 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi just bought rubber brake lines for the front of my barracuda and saw braided ones 4 bucks cheaper each one. Is one better than the other? I did not install these yet, so I can still take them back.
Re: Braided Stainless Steel Brake lines vs Rubber? [Re: cudabitten] #142478
10/27/08 10:29 PM
10/27/08 10:29 PM
IN
ahy Offline
ahy  Offline
IN
Braided expands less under pressure giving a firmer pedal. Not all braided are DOT approved though so its worth checking.
Re: Braided Stainless Steel Brake lines vs Rubber? [Re: ahy] #142479
10/27/08 10:37 PM
10/27/08 10:37 PM
eastern, pa.
eastern, pa.
Ahha, thanks for the theory behind the material. The set I'm looking at are on MagnumHP Web page, does't say anything about DOT. The rubber ons are marked DOT. Thanks for the tip.
Re: Braided Stainless Steel Brake lines vs Rubber? [Re: cudabitten] #142480
10/28/08 04:58 AM
10/28/08 04:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Greg is a stand up guy...I find it hard to believe that he would sell something for brakes that are NOT DOT approved.
his are probably safe to use.
**Photobucket sucks**
Re: Braided Stainless Steel Brake lines vs Rubber? [Re: cudabitten] #142481
10/28/08 08:11 AM
10/28/08 08:11 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I'm sure both sets of lines would do the trick. As for the braided lines giving you a firmer pedal...I think that is a line of bull. The improvement you would gain would be marginal at best as far as the pedal feel goes...if your pedal is already soft, braided lines WILL NOT fix it.
I have known a few people who bought those braided lines and they couldn't tell the difference. That being said, if they are cheaper, and you like the looks...go for it
I myself prefer the stock look of rubber lines.
