Re: 2 guage clusters, Gas guage still dead
[Re: NITROUSN]
#1424720
04/25/13 11:49 PM
04/25/13 11:49 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The top one looks OEM the bottom one does not. I have an OEM valve that works if you need it. Make sure the valve is getting a good ground. They do not click very loud and you can bench test it on a battery to verify it switches.
I may just take you up on the offer!
[Re: Kern Dog]
#1424721
04/26/13 09:31 AM
04/26/13 09:31 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Here ya go Greg. I got mine here. Remember, it's an easy test to see if they're working. Just ground the switch on your - battery post and use a hunk of wire to go to the + post and threaded part of the switch. You should hear an audible click when you touch the + post with the wire! Oh, one other thing, OEM (used) is fine. But unless they're new in the box, I found out that after 30/40 years on a truck, the plastic starts to leak. That's why you see so many of them with epoxy all over them. I finally just went and got a new one at http://www.oreillyauto.com/site/c/search/Fuel+Tank+Selector+Valve+-+Universal/N2000/C0025.oap
