Re: The 340 just keeps making more power! Best slips yet
[Re: 440charger500]
#1424514
04/23/13 11:18 PM
04/23/13 11:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats good... but dont stop there.. if you jetted up 2 sizes and it picked up then go 2 more till your MPH starts to drop then back up 1 size... then after you find the sweet spot then advance the timing some but watch your plugs..... good job
[Re: SpareParts]
#1424516
04/23/13 11:34 PM
04/23/13 11:34 PM
MR_P_BODY
Not too shabby, have you tried 34° timing yet? All our SB's love it. Making a timing and spring change together you really can't credit either. Just my .02
I would have said 34* or so also but with my last SB it liked 39*... we didnt go higher.. I said 39* was far enough... so test, test and test... dont ever think that should be it...........JMO
[Re: SpareParts]
#1424517
04/23/13 11:42 PM
04/23/13 11:42 PM
Posts: 237 Redding,CA USA
440charger500
Redding,CA USA
Timing started @ 35. I dont think the mono leafs changed et much because 60fts stayed the same. I was looking more at the mph for the hp increase. 112mph then 115 now, same DA @ 1000 ft.
[Re: 440charger500]
#1424518
04/24/13 07:57 AM
04/24/13 07:57 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Good deal! I started out with a 71 scamp that had a mild 340 in it, ran 11.70s at 115 at 3200 pounds, lots of fun and very streetable!
[Re: 70Dart499]
#1424520
04/24/13 06:24 PM
04/24/13 06:24 PM
440charger500
Redding,CA USA
Mind sharing your combo? I've got a 340 coming together right now, and I'm curious to hear what your combo is.
340 .030 trw slugs fly cut for closed chamber heads ported eddys 62cc with 10.34to1 comp Lunati voodoo solid RPM Intake with 1" wilson open spacer 750 HP Carb headman Hustlers 3200lb 67 Dart
[Re: 440charger500]
#1424521
04/24/13 09:18 PM
04/24/13 09:18 PM
Posts: 153 Plant city fl
70Dart499
Plant city fl
Thanks, that's very similar to my combo good luck with it.
1970 Dart Drag Car
[Re: 440charger500]
#1424526
04/26/13 01:00 AM
04/26/13 01:00 AM
MR_P_BODY
Actually if the MPH went up you are making more power so the 60' should have dropped some if it was hooking up right... like I said before.. keep going fatter till your MPH drops
