Steer shaft lengths - column to floor conversion #1424281
04/23/13 01:37 PM
04/23/13 01:37 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
Hi all,
does anyone know the actual lengths of the steer shafts for a 71 B body - Satellite - pwwr steering car.
I have 2 - one @ 42" & one @ 40.5", I assumed the 40.5" was for power steering & installed that one in the column but its too short. 72 RRGTX mentioned maybe my shaft was collapsed a bit & I cant find actual measurements on the web anywhere so if anyone has that data its appreciated.
Thanks, evan
Re: Steer shaft lengths - column to floor conversion [Re: edp] #1424282
04/24/13 11:58 AM
04/24/13 11:58 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
somebody's gotta know......do the parts books show length measurements, it doesn't in the FSM.
All help appreciated,Thx.
Re: Steer shaft lengths - column to floor conversion [Re: edp] #1424283
04/24/13 03:58 PM
04/24/13 03:58 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
According to the 1970/1971 factory parts book, The power steering shaft for a 1970 B body is 44.88" and the manual steering shaft is 41.76". They do not list the measurements for the 1971 shaft.
Re: Steer shaft lengths - column to floor conversion [Re: twodoorpost] #1424284
04/25/13 12:30 PM
04/25/13 12:30 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
thanks for that info obviously its kind of hard to come up with.
I swapped out the steer shafts & the original one fits, I'm not sure if the 40.5" one is actually collapsed or is for a different car or what, it came out of a B body column so who knows!
So the answer to What is the steer shaft length for a 71 B body Satellite/RR/GTX power steering car is 42".
