Re: Checking weights in my 440Source stroker kit...
[Re: BradH]
#1424196
04/23/13 05:04 PM
04/23/13 05:04 PM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
I'd be less concerned about minute weight differences and more concerned about measuring the rod & main journals and big ends of the rods for size consistency, taper, out of round, etc. and checking the small ends of the rods for pin clearance.
Yeah, I've checked everything except rod big end bearings, which I will check tomorrow. All has been perfect so far, to me the 440Source stroker kit looks very good. The crank end play is at the bigger end, but this is probably due to the testing the machine shop did when line boring and honing the new billet steel main caps. The thrust bearing sides show signs of the testing.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
[Re: dogdays]
#1424198
04/24/13 04:34 AM
04/24/13 04:34 AM
Swedcharger67
Norrland, Sweden
One comment: Both the connecting rod weight and the piston weight are quite low, that is going to be a very responsive engine!R.
Yes, and considering 512 cui, approx 12.5:1 in static comp, about 9.5 in dynamic, E85 fuel, alu-heads, 1.6 roller rockers with a fairly kind Lunati 703 cam, full engine control...to say I have great expectations is an understatement... But, the engine has become terribly expensive...if I screw it up I will be sorry...but I have noone but myself to blame...
