What heads are these Mopar P4532900? #1424135
04/23/13 01:23 AM
04/23/13 01:23 AM
Maryland
SLEDGEHAMMER Offline OP
Maryland
What heads are these Mopar P4532900? I got these small block heads a while ago and have been sitting in the shop.
1971 Dodge Dart - Powerplant <<TBD>>
Re: What heads are these Mopar P4532900? [Re: SLEDGEHAMMER] #1424136
04/23/13 01:25 AM
04/23/13 01:25 AM
Maryland
Maryland
Here is 2 more shots of the heads.
Re: What heads are these Mopar P4532900? [Re: SLEDGEHAMMER] #1424137
04/23/13 01:31 AM
04/23/13 01:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Some type of magnum head... which ones I dont know
Re: What heads are these Mopar P4532900? [Re: MR_P_BODY] #1424138
04/23/13 01:34 AM
04/23/13 01:34 AM
Maryland
Maryland
Thanks...by the intake I figured they were for a Magnum. The casting number I guess they are Commando's but large or small.
Re: What heads are these Mopar P4532900? [Re: MR_P_BODY] #1424139
04/23/13 01:36 AM
04/23/13 01:36 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Mopar Performance Aluminum Magnum Heads....
Tony
70 AARCuda Vitamin C
Re: What heads are these Mopar P4532900? [Re: SLEDGEHAMMER] #1424140
04/23/13 01:42 AM
04/23/13 01:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The large port cammandos I had didnt use the studs
for the rockers they used the W-2 rockers with offset
shafts... with studs like those they are a magnum
Re: What heads are these Mopar P4532900? [Re: MR_P_BODY] #1424141
04/23/13 02:21 AM
04/23/13 02:21 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Studs....dead give away for a MAGNUM head...not large port or small port commando...
Tony
Re: What heads are these Mopar P4532900? [Re: 70AARcuda] #1424142
04/23/13 03:19 AM
04/23/13 03:19 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Nothing LARGE about them.
Re: What heads are these Mopar P4532900? [Re: goldmember] #1424143
04/23/13 07:17 AM
04/23/13 07:17 AM
Australia
L4staero Offline
L4staero  Offline
Australia
They are the same ports as a small port commando. I belive that is also the same as magnum r/t. Comparable to an edelbrock when ported. Out of the box they are average as they were designed to be ported........lots.
Re: What heads are these Mopar P4532900? [Re: L4staero] #1424144
04/23/13 08:45 AM
04/23/13 08:45 AM
Guitar Jones Offline
The 408 I bought had these heads on it. They are a magnum version of the small port commandos. I don't believe MP sold very many of them if at all. The ones I had came from Dan Dvorak who was supposed to do some R&D on them but he never did. They were sent to Heads by Rick in Vegas who ported them and he claims they flowed 315 on the intake at .650 or .600 I can't remember.
Most people don't speak very highly of them for some reason or another but this 408 went 8.40's in an 1800 pound altered with them at 13.5 compression and a .630 roller cam.
I sold mine to my son and went with my W5's on this motor.
Re: What heads are these Mopar P4532900? [Re: Guitar Jones] #1424145
04/23/13 12:29 PM
04/23/13 12:29 PM
dogdays Offline
dogdays  Offline
Actually, they're junk. I'll pay you scrap price plus shipping and take them off your hands, but that's just because I'm feeling generous.
Seriously, they look like a very capable street head, got me drooling......
R.
Re: What heads are these Mopar P4532900? [Re: dogdays] #1424146
04/23/13 02:34 PM
04/23/13 02:34 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Those are the first Generation of Aluminum Magnum Heads. They were basically a Cammando head they was machined for use in a Magnum Application.
When they were Available through Mopar's catalog they weren't. Now that they aren't any more they have been popping up a lot in various places. Indy had a bunch of them as well as some Ebay dealer out of Dodge Indiana. I bought a set from the Ebay dealer for $500/pr.
Supposedly they can be made to flow around 300cfm, or compariable to an Edelbrock head.
One thing I found out with mine which were missing 1/2 the seats and needed the guides replaced, Is they will only hold about a 2.05" intake valve MAX.
One shop that I know that has done a few sets also said that they found that some of the casting seemed a bit soft as though they had never been heat treated. He had the ones he did Heat Treated.
On the flip side if you look to Mopar for Magnum Aluminum Heads NOW all you will get is Edelbrocks with MOPAR on them.
Also after dropping mine off at the machine shop and the guy looking them over YOU'd be better off buying the Edelbrocks if you're buying new. I could have bought Edelbrocks Complete ready to go and saved a few dollars over what it's going to cost to complete or fix the issues from the ones I bought. And they weren't even used heads. Just never finished.
