Re: how big bore on pre world crate hemi
[Re: billohio]
#1424037
04/24/13 12:04 AM
04/24/13 12:04 AM
Posts: 4,179 California
mickm
California
Its got a sticker don't exceed 4.34. Heard the had some issues and a lot of blocks had stickers. Would like a 4.5!
if it's got a sticker that says don't exceed 4.34, then it is a water block, not a siamese.
don't exceed 4.34!
[Re: mickm]
#1424038
04/24/13 12:13 AM
04/24/13 12:13 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
That was mostly used for building legal ss motors before the world prod ones. Great block but you just cant build a real big motor with it.
JAKES AUTOMOTIVE
[Re: billohio]
#1424042
04/25/13 09:20 PM
04/25/13 09:20 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Going to sonic test my 472 and curious what others have done with boring out block. Its about a 2007 block pre world casting
Is there a decal on the bellhousing flange saying to only bore to 4.340 ? If so it's a siamese bore reject that they couldn't use to build a 528 or sell as a good 4.5 bore. I have one , having it sonic checked , what I have been told is a cylinder or 2 will have enough core shift to make it not a good candidate.
Sleeve the offending holes with a good quality sleeve and let it eat.
[Re: mickm]
#1424043
04/25/13 09:21 PM
04/25/13 09:21 PM
JohnRR
don't exceed 4.34!
that is not the case , I have a 426 crate motor circa 2005 , it's a siamese bore block , or it's cast real bad because I can't pass anything between the cylinders I tried .
[Re: domingo]
#1424045
04/26/13 06:43 PM
04/26/13 06:43 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Don't trust the sticker. Do your own sonic, it might go to 4.5" regardless of the sticker. I have heard of that happening.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1424047
04/29/13 06:08 PM
04/29/13 06:08 PM
JohnRR
Exactly what I had done to the one I have , will have the sheet tomorrow.
And just because it's a new block doesn't mean it was machined correctly, one deck was higher than the other by .002 or .003 , the lifter bore angles were off ...
[Re: JohnRR]
#1424048
04/30/13 01:30 PM
04/30/13 01:30 PM
Hemi_Joel
Minnesota
Please post the results, John, enquiring minds want to know...
