I had a lot of problems with dirty gas in my 72 demon and I finally retired it to the garage to get overhauled. The last thing to do is the fuel system- I have an electric pump and filter, 3/8" sender and aluminum hard line. The pump is ok to deadhead at the carb, so I'm not running a return line.
I know that the nipple on the tank that goes up is the output to the pump, and the other line straight out of the sender is a vent (charcoal canister), but my tank also has a small nipple above the sender, at the top front of the tank. It doesn't have the four nipples on the side I saw when I searched this topic.
If I run the one sender out to my fuel pump/ carb etc, where can I run a vent, and what do I do with the other nipple on the tank? I'd like to avoid the charcoal canister if I can do it safely.
radar
