1970 roadrunner hood indicator bulbs #1423495
04/21/13 11:01 PM
04/21/13 11:01 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi, I was wondering if anyone knew off hand if the auto stores carry the hood indicator bulbs and if so, does anyone know the part number,thnx
Re: 1970 roadrunner hood indicator bulbs [Re: barryv] #1423496
04/22/13 12:13 AM
04/22/13 12:13 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The bulb # is 330..
Check with your local electronic distributor, a box of 10 is like $8..
Just my $0.02..
Re: 1970 roadrunner hood indicator bulbs [Re: Sinitro] #1423497
04/22/13 02:58 PM
04/22/13 02:58 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
thank you
Re: 1970 roadrunner hood indicator bulbs [Re: barryv] #1423498
04/22/13 06:15 PM
04/22/13 06:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Usually tough to find.... www.chargerspecialties.com carries them
This is Charger Speciaties PN#, but it is the miniture 330 bulb
Mike
Re: 1970 roadrunner hood indicator bulbs [Re: barryv] #1423499
04/22/13 06:40 PM
04/22/13 06:40 PM
If you cant find one locally www.classicindustries.com has a extensive selection of bulbs & may have it & after you make a small purchase online (fast turnaround) then in several weeks their comprehensive Mopar specific excellent catalogue will appear in your mailbox for free. Has many pics etc & a good reference to have in your possession
Re: 1970 roadrunner hood indicator bulbs [Re: DAYCLONA] #1423500
04/22/13 06:41 PM
04/22/13 06:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
3 bucks a pop???
So, that's $30.00 for ten...
The Sylvania box I have cost me significantly less than 30 bucks...
Re: 1970 roadrunner hood indicator bulbs [Re: RSNOMO] #1423501
04/22/13 08:51 PM
04/22/13 08:51 PM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
69 Roadrunner 383 stock
Re: 1970 roadrunner hood indicator bulbs [Re: RSNOMO] #1423502
04/23/13 01:21 AM
04/23/13 01:21 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
3 bucks a pop???
DON'T be a cheapee bEASTsider ...share the wealth ... get off some of those big bux you have buried in your back-yard ...
Re: 1970 roadrunner hood indicator bulbs [Re: barryv] #1423503
04/23/13 08:24 AM
04/23/13 08:24 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
ne1 have the wiring diagram for the working hood indicators? is there a harness of sorts for it?
Re: 1970 roadrunner hood indicator bulbs [Re: meepmeep70] #1423504
04/23/13 10:03 AM
04/23/13 10:03 AM
You could solder a line down to the park/ts 1157 bulb & T into the wire for the large filament. www.mymopar.com would have the colors of the 2 wires so you can pick the right one
Re: 1970 roadrunner hood indicator bulbs [Re: meepmeep70] #1423505
04/23/13 06:21 PM
04/23/13 06:21 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
EZ to connect..
Make a short 2-lead harness from the hood over to the middle bulkhead connector, splice in the left & right signals terminals..
Just my $0.02...
Re: 1970 roadrunner hood indicator bulbs [Re: Sinitro] #1423506
04/23/13 07:03 PM
04/23/13 07:03 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
thank you
