Re: Fan diode assy 2000 Cherokee Classic?
[Re: Belvedere1]
#1423461
04/22/13 12:12 AM
04/22/13 12:12 AM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
With the A/C on it should run all the time
That I don't believe is true. The newer styles used a pressure transducer to operate the fan on a/c. The xj may be different. You do have 2 fans....If the a/c does not work the other fan wont run.
[Re: Belvedere1]
#1423463
04/23/13 09:31 AM
04/23/13 09:31 AM
Posts: 311 Mass. USA#1
hemi70
Mass. USA#1
Fuse in the PDC (underhood fuse box) is good? When my 99 xj was new it flickered the headlights when the fan kicked on. Fix was to add some type of elec box to the fan wiring near the fan and mounted to the inner fender near left headlight. Then fan ramped on and no more flicker. Gary.
[Re: Belvedere1]
#1423466
04/23/13 12:27 PM
04/23/13 12:27 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I did a few at work.They were buried in IIRC the pass side and you had to pull a bunch of stuff to get to it.Seems Ma had a problem with them.It should be behind the grill etc.Google it and you should find the location.Rocky
Chrysler Firepower
[Re: Belvedere1]
#1423468
04/24/13 12:22 AM
04/24/13 12:22 AM
hemi70
Mass. USA#1
2000 XJ. Control power is ignition switched thru fuse #10 in JB. It also supplies power to control circuits on A/C clutch relay and o2 relays. With key on there should be B+ on two of the relay pins for the rad. fan relay. Gary.
[Re: Belvedere1]
#1423469
04/24/13 12:34 AM
04/24/13 12:34 AM
NITROUSN
The A/C works fine after a full recharge.
So the electric fan wont work unless you fix the a/c. The mechanical fan will do the job with no a/c. The electric fan is just a booster for higher temps with the a/c on.
[Re: Belvedere1]
#1423471
04/24/13 12:08 PM
04/24/13 12:08 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
the aux fan only supplements the main fan. when the a/c is on, the condenser makes heat, and a lot of it. the extra fan only helps to cool the radiator and condenser. if your a/c isnt cold, you have a leak somewhere. get it checked, or if you've done the r-134 conversion, add some dye to it, and check it yourself. the kit for checking comes with dye and a u.v. light. cost is like 30 bucks, and worth it if you don't mind doing it yourself.
[Re: Belvedere1]
#1423472
04/24/13 07:18 PM
04/24/13 07:18 PM
NITROUSN
I thought the aux fan helps keep the pressure in the A/C system from getting too high.
It does when the pressure is to high which only can get to high when fully charged and working correctly. The pcm activates the fan relay. The pcm sees several things. A switch command, an a/c high pressure signal. When the pcm sees a high pressure signal it activates the relay which in turn activates the fan.
