Engine temp how cool is bad ? #1423131
04/21/13 01:53 PM
04/21/13 01:53 PM
IL . usa
cjs69mope Offline OP
IL . usa
Does Running to cool of operating temps hurt engine's in any way?
Curantly my car has a stroker 493 that only gets to 165 in cool 45 deg weather.
In the hot days of summer she runs 175 unless driven long distance at highway speeds of 60 to 70 mph then i have seen 195.
She is using some oil and i don't have a valley tin .
I am using the Indy valley cover .
Last summer pulled the intake and it was full of oil .
Not sure where it was coming from i thought it might be the Mopar Performance valve covers because the baffles are not that great in side the cast aluminum covers .
I went so far as to make my own baffles to try get less oil sucked in through the pcv valve. running a MP breather on one side and pcv on the other.
What would be my next step ?
She seems to be using about a quart every 50 to 100 miles but does not foul plugs weird. runs good and has great power .
Any ideas?
1969 Dodge Charger 1969 Dodge Superbee
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423132
04/21/13 02:11 PM
04/21/13 02:11 PM
Kirkland, Washington
Pacnorthcuda Offline
I wouldn't concern myself with the operating temp until the EXREME oil consumption issue is solved...
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423133
04/21/13 02:11 PM
04/21/13 02:11 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
I am using ehaust evacs and my intake is full of oil as well, i think its sucking the oil from the intake to head joint.
Hook up some exhaust evacs and run it like that some time and then see if your intake still gets contaminated with oil????
Re: Engine temp how cool is bad ? [Re: domingo] #1423134
04/21/13 02:15 PM
04/21/13 02:15 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
what heads do you have? do you have ported heads with bronze pushrod sleeves? could be sucking oil from there too....
too loose clearance on the valve guides???? bad intake valve seals????
then get into more serious stuff like checking piston rings...that could be your problem, but the last one to check since it takes taking your whole motor apart.
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423135
04/21/13 02:22 PM
04/21/13 02:22 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
That is A LOT of oil usage ... you are going to carbon-up the valves, combustion chambers and ring-lands BIG TIME if you don't straighten that out first.
Re: Engine temp how cool is bad ? [Re: domingo] #1423136
04/21/13 02:46 PM
04/21/13 02:46 PM
IL . usa
IL . usa
The heads are Indy SR They were bowl ported and gasket matched nothing major.
Any way to check valve seals with a bore scope camera?
Already did the leak down test less then 5% across the board.
compression is on the high side like 200 psi but i think because of oil in the cylinders.
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423137
04/21/13 03:19 PM
04/21/13 03:19 PM
Az
Crizila Offline
Crizila  Offline
Az
Any ideas?
Start by running it at idle. With the PCV hooked up, remove the breather on the other valve cover and plug the hole with your hand / finger. You should feel a slight vacuum. If not and you feel pressure, the PCV is not working or you have an excessive amount of blow-by. Also look at the inside of the PCV hose. If it is wet with oil, it may not be shielded proper with those valve covers of blow-by issue again. Only other way oil can get in to the intake runners ( "intake full of oil" )is a bad seal between the heads and intake manifold. You could also try running it without the PCV ( vent both sides ) and see if your oil consumption goes away. Don't think cold engine operating temp has much to do with above - not a qt every 100 miles anyway.
Fastest 300
Re: Engine temp how cool is bad ? [Re: Crizila] #1423138
04/21/13 11:02 PM
04/21/13 11:02 PM
IN
ahy Offline
ahy  Offline
IN
On the temp, cool makes power but can shorten engine life. 180 seems to be the happy medium. I'd be looking for a 180 degree stat. Agree that is second however after you figure out the oil consumption.
Re: Engine temp how cool is bad ? [Re: ahy] #1423139
04/22/13 12:07 AM
04/22/13 12:07 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I run just breathers on my 6 yr old motor and used no oil at all in 1500 miles at Drag Week
some say the evac system doesnt work with an exhaust
Re: Engine temp how cool is bad ? [Re: sixpackgut] #1423140
04/24/13 07:58 PM
04/24/13 07:58 PM
IL . usa
IL . usa
Up date Pulled a couple of valve springs off , My Indy heads have Teflon PC seals on them. They are real Hard. I think this might be the cause of my oil burning issues .
I have read that these do not belong on a street car , ordered comp cams viton pc seals . going to try them.
Guides on the two i have checked so far are Tight like less than 2thou.
I will keep posting what i find.
Need to send the push rods back to get shorten found them to be .130 to long.
Smith Bros said they can shorten for $3.50 a rod . those guys are great! So its going to be a while until i get this thing back together.
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423141
04/25/13 09:18 AM
04/25/13 09:18 AM
an8sec70cuda Offline
I seriously doubt the valve seals are the problem. I know motors w/ no valve seals at all that don't use that much oil.
I'd get rid of the pcv valve, just run rbeathers on the valve covers and try again.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine temp how cool is bad ? [Re: ahy] #1423142
04/25/13 11:18 AM
04/25/13 11:18 AM
Penna
70satelliteguy Offline
Penna
" Only other way oil can get in to the intake runners ( "intake full of oil" )is a bad seal between the heads and intake manifold"
How would this happen with a Indy Valley pan on a BB???
Mike
Re: Engine temp how cool is bad ? [Re: 70satelliteguy] #1423143
04/25/13 02:58 PM
04/25/13 02:58 PM
Az
Crizila Offline
Crizila  Offline
Az
Mike
Oil coming in through the PCV hose.
Fastest 300
Re: Engine temp how cool is bad ? [Re: Crizila] #1423144
04/25/13 03:39 PM
04/25/13 03:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I went with baffled breather grommets on my engine. I just run breathers but they reduced oil leaks through and around the breathers down to hardly anything now. Another problem area is the dipstick tube.
Mopar to the bone!!!
Re: Engine temp how cool is bad ? [Re: 72Swinger] #1423145
04/25/13 04:15 PM
04/25/13 04:15 PM
Penna
Penna
Mike
Oil coming in through the PCV hose."
Not trying to be a wise guy Crizila but how could the oil from the pcv valve in the valve cover going either to the carb or a fitting in the intake manifold via a hose be affected by the seal between the manifold and the heads on a bb with a valley cover? If the oil were introduced into the hose by blowby or getting sucked past the baffles it would get directly into the top of the manifold before it ever came in contact down where the heads and the manifold are sealed would they not???
Mike
Re: Engine temp how cool is bad ? [Re: 70satelliteguy] #1423146
04/25/13 06:13 PM
04/25/13 06:13 PM
Az
Crizila Offline
Crizila  Offline
Az
Mike
Mike
His original post stated "intake full of oil". The objective of the PCV system is to eliminate any cranking venting to the atmosphere. If the PCV valve is working correctly, it should be closed at idle. Above idle, it will open a small amount and introduce a vacuum to the crank case. The PCV hose usually gets its vacuum from the carb base or there abouts. If the PCV valve in the valve cover is not working correctly, not shielded properly from oil splash, or there is excessive engine blow-by, oil will travel down the PCV hose and be introduced in to the intake manifold directly under the carb - and you will have oil in the intake manifold. After market valve covers can often create this problem if they do not shield the PCV valve from oil splash. Only way oil can really get in to the runners on a big block.
Fastest 300
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423147
04/25/13 07:12 PM
04/25/13 07:12 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
This sure sounds like you have a leak to me
Are you sure it's not smoking like a mosquito fogger? Using that much oil it should be.
Or you have a puddle on the driveway.
I've experienced oil pressure idiot light switches that leaked like crazy, but the mess was easy to spot. Also had an oil flood inside the car when the copper line to the oil gauge broke at the gauge
Paul
Re: Engine temp how cool is bad ? [Re: 74DusterP457] #1423148
04/25/13 08:36 PM
04/25/13 08:36 PM
IL . usa
IL . usa
Well for 32 bucks valve seals seam worth a try.
If its not the seals then something must of gone wrong with the rings break in or the pcv is sucking in a lot of oil.
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423149
04/25/13 11:00 PM
04/25/13 11:00 PM
Az
Crizila Offline
Crizila  Offline
Az
GEZ! Why don't you check out the PCV first??? No $, little effort, easy check?????
Fastest 300
Re: Engine temp how cool is bad ? [Re: Crizila] #1423150
04/25/13 11:21 PM
04/25/13 11:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
He did but the finding seems inconclusive. Wise had a great idea to prove or disprove it being the PCV , put a clear fuel filter in the line and see if it gets filled with oil quickly ???
He's been chasing this problem since last summer .
https://board.moparts.org/ubbthreads/show...rue#Post7299460
