Re: what cam should I use in a 431 stroker???
[Re: Pacnorthcuda]
#1423070
04/21/13 06:07 PM
04/21/13 06:07 PM
Posts: 751 Hermiston Oregon
mopar_leaner
Hermiston Oregon
so I am looking for recommendations, what would you run, I have about 1" piston to valve clearance.
[Re: mopar_leaner]
#1423071
04/21/13 06:34 PM
04/21/13 06:34 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
The good old MP 528 cam would work with your basic combo,what rockers do you have? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: mopar_leaner]
#1423072
04/21/13 07:00 PM
04/21/13 07:00 PM
Posts: 1,363 Out of the State of Confusion
blue_stocker
I'm building one myself, albeit quite different with a more performance-minded combination, nonetheless important areas to carefully consider are the oil system (1/2" npt internal pick-up, higher capacity oil pan w/tray and the std volume pump will do fine, as-long-as the flow isn't hindered), an adequate exhaust and fuel system. As for cam choice, the 284x.528" MP stick is a decent choice, however...if you're looking for something more in line with your engine combination and a hyd grind, call Kirk (or one of the other guys) at Bullet cams and discuss it with them. One thing for certain, the quality of the machine work is critical in the performance and longevity so don't scrimp. Don't get excess on sizing or choke it down and that engine should perform quite well.
