Transmission drain plug hole stripped #1423044
04/21/13 12:22 PM
04/21/13 12:22 PM
Ohio, U.S.
73-Dart-sport Offline OP
Ohio, U.S.
Went to change the fluid today and to tighten the drain plug it had no grip. Threads are stripped. It is a TCI aluminum pan. Due to trans shield nylon strap, it may be difficult to get the pan pulled off without lowering tranny. Anyone have any good ideas on a fix? Can the hole be tapped larger with the pan on the car? What about aluminum shavings in the pan? Any help would be appreciated.
Re: Transmission drain plug hole stripped [Re: 73-Dart-sport] #1423045
04/21/13 12:34 PM
04/21/13 12:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
They make engine oil pan self tapper plugs with a smaller removable plug in the center. They come in various diameters. Any local auto parts will have them.
Doug
Re: Transmission drain plug hole stripped [Re: dvw] #1423046
04/21/13 12:56 PM
04/21/13 12:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
Yep... I've used them on oil pans in the past.. they
work fine... or just tap it to a larger fine thread
with a bolt and O-ring
Re: Transmission drain plug hole stripped [Re: 73-Dart-sport] #1423047
04/21/13 12:59 PM
04/21/13 12:59 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
shavings ? ... the filter will prevent the flow of that into the VB and the trans ... NOT to worry.
Re: Transmission drain plug hole stripped [Re: 73-Dart-sport] #1423048
04/21/13 01:07 PM
04/21/13 01:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As to the shavings.. waste a qt or 2 of trans fluid
to flush the shavings out the hole after tapping..
what doenst come out will NOT bother anything and
the filter will take care of it
Re: Transmission drain plug hole stripped [Re: 73-Dart-sport] #1423049
04/21/13 01:15 PM
04/21/13 01:15 PM
Ohio, U.S.
Ohio, U.S.
Thanks for the comments. That will save alot of time. Thanks Mr. P for the suggestion on flushing it with another quart of fluid. Looks like we will keep getting ready for opening day.
