clutch pedal switch #142295
10/27/08 01:55 PM
10/27/08 01:55 PM
Winnipeg,Manitoba
cudablues Offline OP
Winnipeg,Manitoba
Part #3488177,on a 73 Cuda.Cannot find the # in my service manual or parts manual.Also looked online,but no luck.Attaches to the brake/clutch pedal assembly,and is operated by pushing the clutch pedal.I think its a safety switch for starting,but not sure.There is a little pin that sticks out from it and into a loop attached to the clutch pedal.I broke the pin off and not sure if its needed.Thanks for any help
Re: clutch pedal switch [Re: cudablues] #142296
10/27/08 02:02 PM
10/27/08 02:02 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A couple of things..
The clutch pedal switch is a lever micro switch which is normally open and is closed when the pedal is engaged. When closed the switch grounds the starter control relay so the starter can turn over. These switches can be expensive..
You mite want to check with Wayne @ Brewers Performance, he has had these available.
www.brewersperformance.com
937-698-4259
Just my ...
Re: clutch pedal switch [Re: cudablues] #142297
10/27/08 02:42 PM
10/27/08 02:42 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
P/N should be 3514432. P/N stamped on part may be different.
Re: clutch pedal switch [Re: Snoopy] #142298
10/27/08 03:53 PM
10/27/08 03:53 PM
Winnipeg,Manitoba
Winnipeg,Manitoba
Holy ****,290.00.Maybe i can figure a way to rivet a pin back on.What if i dont hook it to the starter?
Re: clutch pedal switch [Re: cudablues] #142299
10/27/08 04:15 PM
10/27/08 04:15 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Remember..
We warned you that it was pricey..
A simple fix..
Just run a short jumper lead from the lower rite terminal of the starter relay to ground..
Note now it will start in any gear even when the clutch pedal is not depressed..
Actually I prefer this way and have been running the RoadRunner for years this way.
Just my ..
Re: clutch pedal switch [Re: cudablues] #142300
10/27/08 04:32 PM
10/27/08 04:32 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
A relatively inexpensive microswitch with the arm bent as required does the same thing.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: clutch pedal switch [Re: Sinitro] #142301
10/27/08 04:33 PM
10/27/08 04:33 PM
Snoopy Offline
Snoopy  Offline
From the 70 FSM
Re: clutch pedal switch [Re: Snoopy] #142302
10/27/08 06:21 PM
10/27/08 06:21 PM
Winnipeg,Manitoba
Winnipeg,Manitoba
Well,i tried JB Weld,so ill see in a couple of days.If it wont hold, ill do the jumper fix.Thanks for the help
Re: clutch pedal switch [Re: cudablues] #142303
10/27/08 06:28 PM
10/27/08 06:28 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
With a reasonably heavy clutch starting the car with the clutch pedel depressed puts a lot of pressure on the dry thrust bearing. I would bypass it if it were working good.
Re: clutch pedal switch [Re: cudablues] #142304
10/27/08 06:28 PM
10/27/08 06:28 PM
BC, Canada
thrashingcows Offline
BC, Canada
Is it just the tip that's broken off....I'd rivet a small "L" shaped piece to the main arm and go with it that way.
Brian
1984/93 W350 Cummins Crewcab, NV4500, 3.54's
1984 Ramcharger Sno-Commander 360/auto
68 Chrysler T/C Station Wagon 440/auto
The only reason people get lost in thought is because it's unfamiliar territory!!
Re: clutch pedal switch [Re: cudablues] #142305
10/27/08 06:57 PM
10/27/08 06:57 PM
Kirkland, Washington
Pacnorthcuda Offline
Gulp!!!
Re: clutch pedal switch [Re: cudablues] #142306
10/27/08 08:24 PM
10/27/08 08:24 PM
Snoopy Offline
Snoopy  Offline
Holy ****,290.00.Maybe i can figure a way to rivet a pin back on.What if i don't hook it to the starter?
That's a 70 only switch, although it will work on your car. I have seen the later model switches for a lot less on eBay. Usually NOS for below $100.
