transmission fluid temperature on tow vehicle #1422813
04/20/13 09:41 PM
04/20/13 09:41 PM
Ohio, U.S.
73-Dart-sport Offline OP
Ohio, U.S.
Transmission fluid temp is about 120 degrees when not towing. Yesterday in strong head wind towing a 24 ft. trailer the temperature went to about 168 degrees. It is a 2004 Silverado 1500 Z71 package. Manual says range of 100 degrees to 260 degrees is normal. Anyone think the above rise in temperature is a problem? It does have a transmission cooler on it from the factory.
Re: transmission fluid temperature on tow vehicle [Re: 73-Dart-sport] #1422814
04/20/13 10:08 PM
04/20/13 10:08 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
...a in-the-rad cooler/warmer AND an aux-cooler ?
Re: transmission fluid temperature on tow vehicle [Re: 73-Dart-sport] #1422815
04/20/13 10:29 PM
04/20/13 10:29 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u won't have any trouble. it's normal for temps to rise with more strain. allison's with retarder's see sump temps at 220. retarder temps as high as 275. ur good.
Re: transmission fluid temperature on tow vehicle [Re: 73-Dart-sport] #1422816
04/21/13 12:36 AM
04/21/13 12:36 AM
I use to see a lot higher temps. when towing my 24 ft enclosed trailer in the Mojave desert in the summer in my 1998 24 valve CTD with automtic, 230/240 F up hill(17 miles up Baker grade CA) at 70 MPH with the air on in high gear and locked out of O.D. It would run between 160 and 190 F on the flats towing at speeds in the summer, a lot colder when not towing I would like to see at least 160 F at all times or higher Some of the color additives in most ATF start to change colors at or above 275 F and then will turn black at or above 325 F Your golden
Re: transmission fluid temperature on tow vehicle [Re: Cab_Burge] #1422817
04/21/13 12:57 AM
04/21/13 12:57 AM
Ohio, U.S.
Ohio, U.S.
Thanks for all responses. Sounds like we are okay.
Re: transmission fluid temperature on tow vehicle [Re: 73-Dart-sport] #1422818
04/21/13 01:02 AM
04/21/13 01:02 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
So Dave, did you buy a trailer?
Re: transmission fluid temperature on tow vehicle [Re: moparguy7074] #1422819
04/21/13 08:25 AM
04/21/13 08:25 AM
Ohio, U.S.
Ohio, U.S.
Yes. With an expected increase in racing this year we finally decided to get an enclosed trailer. How is your car coming along? Will we see you next week at Norwalk's opening points race? Let me know when you plan to go over. Are you going to the test n tune on Friday night?
