need a prediction - 02 3.5 L Intrepid threw timing belt
#142279
10/27/08 12:58 PM
10/27/08 12:58 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Wife cruising along at 60 MPH Car died. She tried to restart Tow truck driver tried to restart Some other guy tried to restart
I get home from out of town, car dead in driveway
Take fornt end off, tensioner bolt broke. Timing belt massive FUBAR
I am getting warranty belt and tensionser, new oil pump housing.
Question, when I go to restart, how much damage do you think there will be to the valves? This is an interference engine. Each rotation was making a piston hit at least two sets of valves. How bad is the damage is your guess?
Should I do a compression check or just try & fire the car up?
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: need a prediction - 02 3.5 L Intrepid threw timing belt
[Re: Blown71X]
#142283
10/28/08 08:47 AM
10/28/08 08:47 AM
70Coronet500Vert
St Charles MO
Well, I just put a belt, tensioner, radiator, water pump, new belts and hoses on it a month ago.
The damn bolt in the new tensioner sheared off at the oil pump housing. So I am buying a new oil pump too.
It is suppoed to be 70 degrees here onThurs. I am gonna try & take off early & put it back together. So far the hardest thing is the damn oil pan. That is a VERY tight fit. Someone said use ramps instead of letting the front wheels hang and it will come off easier.
[Re: buildanother]
#142285
10/28/08 10:37 AM
10/28/08 10:37 AM
70Coronet500Vert
St Charles MO
I'll try that too.
This thing is a major PITA. Cast aluminum, no flex and thick.
[Re: 70Coronet500Vert]
#142286
10/28/08 10:47 AM
10/28/08 10:47 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
Why not just drill the remains and remove it, been there done that lots of times...once the bolt is drilled you do have to apply some heat to the bolt to loosen the thread locker that is applied to it. No way would I replace a pump housing for just a broken tensioner bolt.
Rick
