Help with Valve Body ID #1422511
04/20/13 02:32 PM
04/20/13 02:32 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Picked up a used 727 valve body. Previous owner is not sure of brand but says it is a reverse manual. Could I get some help with the ID?
It has a red separator plate with 1218 stamped in it. Not alot of other info on it. I have more pics & it's apart for a thorough cleaning.
Re: Help with Valve Body ID [Re: 80fbody] #1422512
04/20/13 04:00 PM
04/20/13 04:00 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
looks like a TCI
Re: Help with Valve Body ID [Re: Mr340] #1422513
04/20/13 04:04 PM
04/20/13 04:04 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
It does look like a TCI but I've noticed others use the red plate as well. John Cope's are red too. Want to make sure I set the trans up correctly to match the manufacturer's instructions.
Also, is there an easy way to tell whether it really is a reverse manual?
Re: Help with Valve Body ID [Re: 80fbody] #1422514
04/20/13 04:42 PM
04/20/13 04:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it is a manual VB there will be some holes in the rear of the red plate that aren't used (pic doesn't show rear).
Also the throttle valve will be jammed wide open (there won't be any spring feedback when turning the throttle lever shaft).
Re: Help with Valve Body ID [Re: John_Kunkel] #1422515
04/20/13 05:38 PM
04/20/13 05:38 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
John, long shot but you wouldn't have a diagram for a manual valve body. I took it apart to clean it. Figured I could use my 727 books to reassemble as I've done with stockers. Kind of jammed myself up as there are several differences & I'm not sure it'll work.
Re: Help with Valve Body ID [Re: 80fbody] #1422516
04/20/13 09:44 PM
04/20/13 09:44 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
http://www.jegs.com/i/TCI/890/121700/10002/-1
TCI 121700 Reverse Manual VB
http://www.jegs.com/i/Hughes-Performance/512/HP1218/10002/-1?parentProductId=760486
I believe the 1218 is the same as a 1217, but it is a transbrake with external solenoid that screws into the neutral safety switch threaded hole. Old design. You don't show a solenoid or push rod, so they may be missing.
Re: Help with Valve Body ID [Re: DusterW2] #1422517
04/21/13 11:22 AM
04/21/13 11:22 AM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Ya, no solenoid or rod was included. I'll have to call TCI in the morning to see if they can ID it & send me a schematic for it.
Hopefully I'll be able to still use it even if the transbrake pieces are missing.
