Re: Help with Valve Body ID
[Re: 80fbody]
#1422514
04/20/13 04:42 PM
04/20/13 04:42 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it is a manual VB there will be some holes in the rear of the red plate that aren't used (pic doesn't show rear).
Also the throttle valve will be jammed wide open (there won't be any spring feedback when turning the throttle lever shaft).
