4.15 B engine stoker crank/chevy rods
#1422493
04/20/13 02:19 PM
04/20/13 02:19 PM
Posts: 2,512 PA
moparacer
PA
Anyone know if there is a source for a 4.15 stroke, 6 bolt, 400 main stroker crank with chevy 2.20 rod journals?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: 4.15 B engine stoker crank/chevy rods
[Re: MR_P_BODY]
#1422495
04/20/13 02:56 PM
04/20/13 02:56 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would give either Todd @ Competition Wedge or Dan @ Performance only or Bob @ Bob George Racing a call. All members and you can't go wrong with any of them.
[Re: Cab_Burge]
#1422500
04/20/13 03:33 PM
04/20/13 03:33 PM
Posts: 99 Nv
Bill Koski
Nv
[Re: Bill Koski]
#1422501
04/20/13 06:47 PM
04/20/13 06:47 PM
Posts: 3,441 Mo.
supercomp
Mo.
K1 makes one. 383-4150TC6F
[Re: supercomp]
#1422502
04/20/13 11:01 PM
04/20/13 11:01 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
That is correct Supercomp. That is the low deck 4150 X 2.200 crank. I just checked on one of these last week.
The Eagle dont have 2.200, nor do the RPMS, but they do both make a 4.150 low deck, just not 2.200. The 6 bolt stuff is a little tougher to get usually.
RIP Monte Smith
[Re: moparacer]
#1422504
04/21/13 11:02 AM
04/21/13 11:02 AM
Posts: 3,441 Mo.
supercomp
Mo.
Must have changed it. We bought one last year and it was a 6 bolt. Better call. Same part number.
[Re: supercomp]
#1422505
04/21/13 12:14 PM
04/21/13 12:14 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Yeah, the 6 in the PN used to correspond to the number of holes in the flange.
[Re: moparacer]
#1422506
04/21/13 02:46 PM
04/21/13 02:46 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I am pretty sure Molnar Technologies makes a 6 bolt 4.15 crank. contact http://www.4secondsflat.com/ and ask for a quote, you won't believe the price. I just got a 4.25 stroke and it is dead on spec. Joe
Without Data, you’re just another guy with an opinion.
[Re: 64Post]
#1422507
04/21/13 05:20 PM
04/21/13 05:20 PM
CompWedgeEngines
Syracuse,NY
Actually not true. The 6 is the number of counterweights. Here is how that part number breaks down: 383 is obvious 4150 stroke J is main journal ( Chysler Hemi) C is 2.200 rods 6 is counterweights F is forged crank What K1 and Molnar ( Molnar used to BE K1) did, was use the prefix " 426" for any BBM crank with 8 bolt flange, and " 440" for any crank that was 6 bolt flange.Since Wiseco bought out K1, maybe they made some changes in that regard. 383-4150TC6F used to be the old K1 part number. T standing for 383/400 BBM, more so for counterweight dimensions. I will try to get ahold of Molnar today and get an answer. I was pretty sure the old K1 383/400 WERE 6 bolt. Perhaps that has changed as mentioned. I have been trying to get a few of these guys to get more 6 bolt cranks, as many people have exisiting 6 bolt parts, and to be honest, there is no big gain in the 8 bolt style for most applications anyhow. It was from the Hemis years ago, and everyone simply stuck with it because they felt the 8 bolt Hemi pattern was superior. I have still yet so see anyone tear 6 bolt outta the crank flange,...
RIP Monte Smith
[Re: CompWedgeEngines]
#1422508
04/21/13 09:21 PM
04/21/13 09:21 PM
64Post
Baltimore/Denver
Well that's what I get for ASSuming...
[Re: 64Post]
#1422509
04/22/13 01:41 PM
04/22/13 01:41 PM
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
#1422510
04/22/13 03:21 PM
04/22/13 03:21 PM
64Post
Baltimore/Denver
Oh, dont worry 64, we ALL been there a time o r two!..
Molnar only has 8 bolt flange for that crank folks, no 6 bolt. I would much rather change the flexplate to 8 bolt than grind the 2.375 journals down. ( unless this is a stick car?)
How hard could it be to reprogram the CNC to do a 6-bolt flange?
