NEED HELP ON 70 ROADRUNNER DASH HARNESS #1422469
04/20/13 01:48 PM
04/20/13 01:48 PM
milwaukee
superbird Offline OP
milwaukee
need help i.d. ing a couple of wires on the dash harness down by the horn relay and the
door switch wires they were not on original harness. put in a year one harness and it seems to be a little different
its the blue and the blue with a white tracer that go into the same eyelet and the two green that also go into the same eyelet that i need help with
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: superbird] #1422470
04/20/13 06:04 PM
04/20/13 06:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I just give you everything I have for the 70 Bev/Sat/RR/ you make with it what you can...
Mike
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422471
04/20/13 06:05 PM
04/20/13 06:05 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
2
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422472
04/20/13 06:06 PM
04/20/13 06:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
3
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422473
04/20/13 06:06 PM
04/20/13 06:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422474
04/20/13 06:07 PM
04/20/13 06:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422475
04/20/13 06:08 PM
04/20/13 06:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422476
04/20/13 06:09 PM
04/20/13 06:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422477
04/20/13 06:09 PM
04/20/13 06:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
8
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422478
04/20/13 06:10 PM
04/20/13 06:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
9
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422479
04/20/13 06:11 PM
04/20/13 06:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
10
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422480
04/20/13 06:11 PM
04/20/13 06:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
11
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: DAYCLONA] #1422481
04/20/13 06:21 PM
04/20/13 06:21 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I think the reproduction harnesses have a few of the accessory harnesses included. Was there an A/C vs. non-A/C choice?
There is a pair of 14 ga. "dark green" for the A/C heater blower motor resistor.
?? There's a "dark blue" & "gray w/tracer" for the tach. ??
Your pic isn't working - repost or email the wires/connectors in question.
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: 6bblgt] #1422482
04/20/13 09:02 PM
04/20/13 09:02 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
I think you need to look at the 70 charger wiring diagram,the repo harness has the wiring for the electric headlight motor and the roadrunner has the rallye dash also.
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: 1970A13] #1422483
04/20/13 09:14 PM
04/20/13 09:14 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
70 Chargers use the blue@white and green wire for the headlight doors relay.
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: WINGCARS_6970] #1422484
04/20/13 10:14 PM
04/20/13 10:14 PM
milwaukee
milwaukee
thanks guys sure wish i could get my picture to post.
so if and when i get this car together will these wires be hot?
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: WINGCARS_6970] #1422485
04/21/13 12:50 AM
04/21/13 12:50 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
70 Chargers use the [Email]blue@white[/Email] and green wire for the headlight doors relay.
Correct....these wires are 7O Charger only for the headlight relay. Just tape them up individually and you should be fine.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: NEED HELP ON 70 ROADRUNNER DASH HARNESS [Re: 70gtx440dana] #1422486
04/21/13 09:37 PM
04/21/13 09:37 PM
milwaukee
milwaukee
thanks again guys
