Bleeding Wilwood brakes having issuses and ?'s UPDATE #1422429
04/20/13 01:35 PM
04/20/13 01:35 PM
in a chair
mopartony Offline OP
in a chair
Ok guys more issues that I am scratching my head over. Might be too much stress and just not having my head into it or I am too close and not seeing something.
Due to the car sitting for 2 years, the car being heavier than what the old Wilwood rear brakes were rated for, the M/C bypassing, a locked wheel cyl and finally a caliper not working correctly(not retracting at all.
I have changed everything but the lines, line lock and the 2psi residual valve I had on for the front brakes. So now I have all the lines back on, the front and rear brakes back on, Wilwood disc all the way around. I used a vacuum bleeder to get fluid into all the calipers but they seem to still be moving air. I have gone through a quart of fluid and still getting air.
The pedal also goes right to the floor no pressure shows on the brake gage. I do not think the calipers are fully full with the pistons extended to the normally engage point.
Still air in the system?
Is a quart normal for all new calipers (4 piston), M/C and lines?
Should I rig up something to let it gravity bleed? I would have to make something as the M/C is in the floor. But I could hook it up to the brake gage and do it.
Thoughts?
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: mopartony] #1422430
04/20/13 02:13 PM
04/20/13 02:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tony .. have you bled both bleeders on each caliper...
are you sure you dont have a fitting loose... did you
bleed the master first... you could have a bad master...
a QT should do the whole job easy... thats one thing
about using a vac bleeder.. you dont use pressure and
it sucks in air and doesnt show leaks easily(no fluid
leaking)
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: MR_P_BODY] #1422431
04/20/13 05:33 PM
04/20/13 05:33 PM
Guitar Jones Offline
Bench bleed the master first, this can take a bit of time. Then gravity bleed the entire system starting with the farthest bleeder from the master cylinder. Go around the car several times. Apply the pedal to push the pistons out, do not pump it rapidly as this just airiates the fluid. Gravity bleed some more then with an assistant pressure bleed starting at the farthest bleeder first by applying pedal pressure, opening the bleeder than closing it before the pedal is released again.
I'm sure you know all this, sometimes we just need a reminder.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: Guitar Jones] #1422432
04/20/13 07:47 PM
04/20/13 07:47 PM
in a chair
in a chair
Thanks guys,
the M/C was bench bled, well it was in place and bled. I will figure out a way to gravity bleed the system. With the M/C in the floor I will have make something and use the port bleed at gage which is higher than all calipers.
I will then bleed it around like stated. Yes that is what I figured meaning I was getting it right but good to hear I was only missing the inside bleeders which I missed on purpose figuring I would be able to get pedal and bleed those when I was doing a final bleed.
Thanks again, I am on it.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: mopartony] #1422433
04/20/13 10:22 PM
04/20/13 10:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How much are you opening the bleeder?
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: mopartony] #1422434
04/20/13 11:26 PM
04/20/13 11:26 PM
MN
hemidup Offline
hemidup  Offline
MN
I had a similar issue when converting over a 71 Charger R/T from brake drums to the Wilwood disc's. Mind you this was a brand new kit. Figured it'd be an easy afternoon job since I've done the conversion many times before. BTW, I hate safety wire lol
I put everything together, used a vacuum pump to bleed the brakes as always and no pedal. I figured there was air in the system so I kept bleeding and bleeding to no avail. I think I put close to 3 qt's through it. Figured I got a bad MC so I ordered another one. Still no help.
On my 2nd day of trying to get some pedal pressure I pulled the wheels off, had a bud jump into the car and lifted him on the lift and planned on bleeding the brakes the old way. However this time around I used a small dead blow hammer and tapped on the calipers in hopes to dislodge any trapped air at the pistons. I remebered this trick when installing a Baiar disc brake system in a Mustang.
I started on the right rear tapping the calipers with the dead blow while bleeding when I seen a burp of air come out of the line and he hollars down...I got pedal, not much and its soft, but I got pedal. A short time later the brakes worked like a million $$$. Just my
Jerry Williams.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: hemidup] #1422435
04/21/13 02:17 AM
04/21/13 02:17 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
The rubber mallet works well to remove trapped air, just some light taps, and as MR.P Body stated you must bleed both bleeders on each caliper.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: loaderpro] #1422436
04/21/13 03:35 AM
04/21/13 03:35 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Based on your description, is your master cylinder LOWER than the calipers??
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: MRMOPAR] #1422437
04/21/13 10:15 AM
04/21/13 10:15 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
this will certainly make bleeding brakes a little more difficult, but not impossible. just have to be absolutely sure that you don't have fluid coming back up out of the lines and into the master.
**Photobucket sucks**
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: 70Cuda383] #1422438
04/21/13 12:55 PM
04/21/13 12:55 PM
in a chair
in a chair
I will use the tap trick when I am ready to maually bleed them.
Yes M/C is lower.
Bleeder is open 1/2 to full turn, it is loose/woobly.
I have the 2psi residual valves in the lines as needed.
I got home late and started on the gravity bleed set up. I am going to gravity feed the fluid through the port in the brake pressure gage, or hope to. I will finish that when I get home from work and see how it goes. If that does not work I will do it the old fashion way, manually. I need to get the car back up on jacks and wheels off so I can bleed without getting fluid all over the place. Yes I will do both bleeders.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: mopartony] #1422439
04/21/13 01:01 PM
04/21/13 01:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tony, get some hose to fit on the bleeder and save
the fluid coming out to a jar.. saves on making a mess
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: MR_P_BODY] #1422440
04/21/13 01:41 PM
04/21/13 01:41 PM
in a chair
in a chair
That is part of my little set up. 1/16 hose is hard to find here in Tucson. Those bleeders are tiny....
I have a clean container too. Going to put a hole in the top and feed the hose in so it is a little less mess.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: mopartony] #1422441
04/21/13 02:16 PM
04/21/13 02:16 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Bunch of info on the internet re using a 2lb residual valve when the MC is lower than the calipers. Among other things, that condition can cause flowback from the caliper, retracting the pistons, resulting in longer pedal travel.
A 2lb residual valve, used mainly to keep the flow of fluid from flowing back to the master cylinder from the calipers and brake lines in applications that have the lines and or calipers higher than the master cylinder.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: MRMOPAR] #1422442
04/21/13 02:53 PM
04/21/13 02:53 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If you tighten the bleeder to tight it will cause the brass seat to crack and you will never get a peddle. I have done that a few times on my stuff.
Sometimes a line lock has a off size and normal break fittings seem to be just out of tolerance.
Once you start getting a little peddle just keep pumping and holding. Leaks should show them selves after a few cycles
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: MRMOPAR] #1422443
04/21/13 05:37 PM
04/21/13 05:37 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Residual valves are designed to keep the pucks or shoes close to the rotor or drums. It does not matter if they are floor or firewall mounted. All the chassis cars that I have seen all have the m/c mounted on the floor. Disc brakes require 2 lb valves and drums use 8-10 lb valve. It sounds as if the OP has all the componants he needs, just has to get the air out.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: loaderpro] #1422444
04/22/13 10:47 AM
04/22/13 10:47 AM
in a chair
in a chair
I found 2 leaks letting it sit over night. The fitting at the M/C is leaking and one of the fittings going into the residual valve for the front brakes.
Both have been tightened up. The residual valve may leak again. If it does I will pull it off the car and tighten it on the bench.I cracked the bleeders at the fronts on both sides and had fluid trickle out. did not see any bubbling though. The auto store by my house did not have half the stuff I needed so I will be finishing that up today. Hope to have teh gravity bleed set up tonight.
I even had fluid at the head of the gage so i am really thinking I paniced early and just need to keep bleeding manually because of the calipers were fully contracted, plus all the air in the lings.
Anyone ever use the bleeders with the check valve in them? Are they any good? Saw those but did not want to spend the $40 it would take to get enough for the Wilwoods.
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: mopartony] #1422445
04/22/13 11:05 AM
04/22/13 11:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Save your money on those bleeders Tony... once you
get it bled you wont touch it for years... its not
like you have to do this every week
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: MR_P_BODY] #1422446
04/22/13 06:42 PM
04/22/13 06:42 PM
in a chair
in a chair
Got you but I am a one man band down here... I know there are guys here in Tucson but no idea how close they are to me.
I will save the $$ already blew too much on this little project...
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: mopartony] #1422447
04/22/13 08:17 PM
04/22/13 08:17 PM
Arizona
Chris'sBarracuda Offline
Arizona
FWIW.. My M/C is floor mounted and I took the residual valve out of mine and it worked better..
Chris..
Re: Bleeding Wilwood brakes having issuses and ?'s [Re: Chris'sBarracuda] #1422448
04/23/13 11:41 AM
04/23/13 11:41 AM
in a chair
in a chair
Chris I will keep that in mind if I keep having issues.
I did get the leaks stopped. Bone dry when I got home. So sitting for 24 hours it did not leak.
Not to button it up and get them bled.
