Cloyes Hex-A-Just Questions 9-3125A #1422424
04/20/13 12:49 PM
04/20/13 12:49 PM
Central California
MoParFish Offline OP
Central California
Just looking for a little experienced advice. Was degreeing the cam (solid roller 240# seat .674 lift) and got to thinking about the hex adjust setup. Seems if the bolts were to loosen up at all, the gear would slip and timing would be lost. The little hex adjuster fits kinda loose and slops around a bit even after bolts are tight. Makes it nice for adjustment though. I did a quick search and there are some chevy guys that wont use em with heavy springs. Mine springs aren't too heavy but not weak either. Was thinkin of using the 9 way version instead (9-3625TX9). Am I thinkin straight? Anyone had issues? Any input is appreciated.
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Cloyes Hex-A-Just Questions 9-3125A [Re: MoParFish] #1422425
04/20/13 01:40 PM
04/20/13 01:40 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I have the same gear set and havent had it slip yet and my spring pressure is 900 open... I also used red locktite on the cam bolts..
Speaking of which.. I did have problems finding the right bolts that would fit with the right cam button.. Good luck to you..
Re: Cloyes Hex-A-Just Questions 9-3125A [Re: Jeepmon] #1422426
04/20/13 07:20 PM
04/20/13 07:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I loved mine in a 500" low deck with a 706/661 lift roller. Just thread lock the bolts and tighten them good.
Re: Cloyes Hex-A-Just Questions 9-3125A [Re: ProSport] #1422427
04/20/13 08:09 PM
04/20/13 08:09 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
I'm using one and had the same issue with the adjusting button feeling loose when the bolts were tightened. It doesn't move enough to affect the timing though. Also I bought the timing chain cover from AndyF. And had problems with finding proper bolts due to the design change of the top gear. But after a little all is good.
Re: Cloyes Hex-A-Just Questions 9-3125A [Re: 440forPOWER] #1422428
04/20/13 10:22 PM
04/20/13 10:22 PM
AndyF Offline
AndyF  Offline
ARP bolts used to fit but now you might need to use a button head bolt. Not sure why they changed the design, it doesn't seem to be an improvement.
