Ram 1500 5.7 hemi HD vs LD cooling #1422221
04/19/13 06:09 PM
04/19/13 06:09 PM
Gaines, PA
Scott360 Offline OP
Scott360  Offline OP
Gaines, PA
Anyone here know the exact differences between the LD cooling and HD cooling options
Re: Ram 1500 5.7 hemi HD vs LD cooling [Re: Scott360] #1422222
04/19/13 06:32 PM
04/19/13 06:32 PM
Gaines, PA
Scott360 Offline OP
Scott360  Offline OP
Gaines, PA
I am specifically wanting to know What thehd cooling option included. I have the light duty cooling and would like to swap this truck up to the HD cooling
Re: Ram 1500 5.7 hemi HD vs LD cooling [Re: Scott360] #1422223
04/20/13 06:58 AM
04/20/13 06:58 AM
Gaines, PA
Scott360 Offline OP
Scott360  Offline OP
Gaines, PA
I guess the year would help. Its an 08, considerable tow capacity difference between ld and hd
Re: Ram 1500 5.7 hemi HD vs LD cooling [Re: Scott360] #1422224
04/20/13 06:34 PM
04/20/13 06:34 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
To be honest with you I think there is very little difference between the two. I had HD cooling on my 04 3/4 ton off-road 4x4 with snow plow prep. and could see no difference in it other than a slighly larger trans cooler as opposed to a truck with standard cooling. The radiatior looked to be no bigger than a standard duty. I was expecting a huge radiator like in 86 W250 with max cooling. Big difference between it and a standard radiator.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Ram 1500 5.7 hemi HD vs LD cooling [Re: 71yelladustr] #1422225
04/21/13 07:05 PM
04/21/13 07:05 PM
Gaines, PA
Scott360 Offline OP
Scott360  Offline OP
Gaines, PA
that's what I thought , if you look up parts such as radiator etc there is no distinguishing, it lists just the one part #(aftermarket)
Re: Ram 1500 5.7 hemi HD vs LD cooling [Re: Scott360] #1422226
04/21/13 07:54 PM
04/21/13 07:54 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Based on what I know, I think it is a larger trans cooler, and a different fan clutch (engages sooner, stays on longer)
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Ram 1500 5.7 hemi HD vs LD cooling [Re: VincentVega] #1422227
04/21/13 08:40 PM
04/21/13 08:40 PM
Gaines, PA
Scott360 Offline OP
Scott360  Offline OP
Gaines, PA
been looking up parts associated and I think that is the only difference, even the radiator is the same up through the 2500 series with the 5.7. thanx for the help.
