pinion seal... this is confusing
#1422191
04/19/13 05:45 PM
04/19/13 05:45 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
what should be the pinion seal on my 489 ?
I have at this moment the 7215 national seal, but have failed twice in 3 or 4 years
yes I have read all the guides about the 8.75 axle, but trust me is still confusing. Specially when you go to rockauto and appears 3 or 4 diff seals.
Re: pinion seal... this is confusing
[Re: NachoRT74]
#1422192
04/19/13 08:30 PM
04/19/13 08:30 PM
Posts: 3,609 Southern Oklahoma
wildman340
Southern Oklahoma
5126 for the 489 and 9.25 rears. A 7216 is for the 742.
1974 Dodge Dart Sport 340 4 Spd Endless Project
1999 Ram 1500 CC 5.2 5 speed
[Re: wildman340]
#1422193
04/20/13 12:25 AM
04/20/13 12:25 AM
NachoRT74
Valencia, España
is it posible the 7215 is a replacement PN for 5126 or backwards ?
the 7215 I got from a Mopar dealer is leather... if makes some difference
[Re: NachoRT74]
#1422194
04/20/13 12:59 AM
04/20/13 12:59 AM
wildman340
Southern Oklahoma
The 5126 number is correct for National or Timken seals, and available at almost all part stores. The 7215 from what I have researched is for the 657 third member.
[Re: wildman340]
#1422195
04/20/13 12:02 PM
04/20/13 12:02 PM
NachoRT74
Valencia, España
found on a National seal PDF chart there is an outer diameter difference between 7215 and 5126 seals, being the fist one bigger by 0.183" thats too much diff to make it fit on my case.
I don't get it.
[Re: DoctorDiff]
#1422197
04/20/13 12:15 PM
04/20/13 12:15 PM
NachoRT74
Valencia, España
So yokes are the same between 741s and 489s ? ( aside the cross joint size )
[Re: DoctorDiff]
#1422199
04/20/13 12:31 PM
04/20/13 12:31 PM
NachoRT74
Valencia, España
nice.
still wondering why I got from the seller the 7215, twice... and made it fit... national catalog states 3" outer diameter
althought he overwritte on box with a pen the number 5126
[Re: DoctorDiff]
#1422201
04/20/13 12:37 PM
04/20/13 12:37 PM
NachoRT74
Valencia, España
ok BTW Cass, there is a guy on FB needing the spider cross shafts for 8.75 clutch SG... do you have them ?
[Re: NachoRT74]
#1422202
04/20/13 12:37 PM
04/20/13 12:37 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The u/joint size can be the same in all three 8 3/4 case set ups depending on the application even a lot of the half ton 4X4's used the small joint.
[Re: MoparforLife]
#1422203
04/20/13 12:39 PM
04/20/13 12:39 PM
NachoRT74
Valencia, España
yes I know, just stating than even with cross joint diff, rest of joke fits the same ( talking about same splines too ) cleared
