Re: 440 too rich and pinging. why.
[Re: willard]
#1421992
04/19/13 11:43 AM
04/19/13 11:43 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
VERY INTERESTING!!! I'm on an ALLMOST EXACT situation with a MORE LESS similar engine specs ( but stroked 400 3.75 ). Pings at around 4K RPMs or in the front to rear butterflies opening transition ( I think, or at least I think to feel it at gas pedal ), when giving gas because I'm requiring power going up a hill. I'll be allert to this thread ![](/ubbthreads/images/graemlins/scope.gif)
[Re: Challenger 1]
#1421994
04/19/13 12:00 PM
04/19/13 12:00 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
give it more initial timing and shorten the slots in the dist.
![](/ubbthreads/images/graemlins/iagree.gif)
Most BB configurations will like more initial timing than just 10*. You will probably find going to 16* (or more) initial will help tremendously here. Unfortunately, this is going to make the motor more likely to ping at higher RPMs (with your hi compression) so as Challenger said, you will need to shorten the slots on the distributor to stop it from advancing too far.
Other than that, you could try higher octane fuel and/or a more agressive cam but the distributor fix should be the easiest way to start fixing this problem! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Challenger 1]
#1421995
04/19/13 01:14 PM
04/19/13 01:14 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Turn the initial/mechanical split around.
20 initial, 10 mechanical and it will run better.
10 initial is not enough timing.
[Re: willard]
#1421999
04/19/13 09:30 PM
04/19/13 09:30 PM
RapidRobert
I'd set the initial with the "vacuum gauge method" & yes you need more than 10 then shorten the slots to get 36 total then play with spring/combo staying just under the pinging point at WOT up thru the gears & you may need heavier springs. I'm thinking that ain't too wild of a cam & if not I'd solder the butterflies closed & concentrate my efforts on the dual carb system (not sure if you're on both idle circuits or not) & I'm not knowledgeable on dual carb setups. You would want the butterflies closed their normal amount or close to it I'd think. Make sure the floats ain't waterlogged & their level is correct & check fuel psi. Holler how it goes
[Re: willard]
#1422001
04/20/13 11:26 PM
04/20/13 11:26 PM
RapidRobert
I have a dual quad '58 era iron single plane intake with a pair of 4131 OE 3 step AFB's converted to eddy 2 step rods/jets going onto a 451 so I will be learning how to tune them also (the idle circuits are my concern). I'd set the initial with the vacuum gauge method then shorten the slots to get 36 total then check/correct a few things on the carb setup: floats not waterlogged/correct float level settings/fuel psi within limits. Then concentrate on the idle mixture screws/throttle position to get it to idle acceptably (which I think'll be the hard part) then play with the springs staying just under the pinging point at WOT up thru the gears. then hookup/tune the vacuum advance if you want to use it (& I would). EDIT Not sure if you need to change anything with the holes in the throttle blades or not
[Re: lokalik]
#1422006
04/22/13 01:18 PM
04/22/13 01:18 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
What size Edelbrocks? (post the number(s) if possible) My gut impression is it's lean, not rich. Both will cause a fuel smell, and both will cause pinging that won't go away once it starts. Other things to check: what radiator is in it? What's the operating temp? Does it ahve an overflow? What pressure is the cap?
[Re: willard]
#1422009
04/22/13 08:27 PM
04/22/13 08:27 PM
Challenger 1
Cincinnati, Ohio
We tested the car yesterday and when really hot it started slightly ping even with 8/28* setting. Pinging occured at every rpm/load. We wait for the package with different distributor springs. One more fact - the engine diesels for 1-2s after shut off. We tried 3 different plug heat ranges and no difference. Also minimizing advance even to 0/20* does not eliminate it. Idle is 900 rpm.
It sounds lean, richen it up and get the distributer squared away. Springs are not going to fix it at this point.
[Re: Challenger 1]
#1422010
04/23/13 06:57 AM
04/23/13 06:57 AM
Posts: 106 Poland
willard
Poland
News: Marcin tried shortenning the slots and eliminated the play on the thick spring in the distributor. He got 15*/28* then and the idle rpm rose so he could close the throttles a little bit. The idle got better, the throttle response is much better now and... no pinging during 4 miles of ride.
Also the dieseling is gone!
The induction is 2x600 cfm edelbrocks and idle vacuum 16", the metering rods are suck down at both N and D.
Edit: whether it is lean on the main circuit - plugs look great (Marcin is a long time moto mechanic) but idle burns eyes. When I follow him in my challenger every time he nails it I see a puff of black smoke and I can even smell the gas! So I doubt the secondaries are lean.
The CR is high as he used special order forged pistons with 4cc pockets, flush with the deck and stealths are milled over 0.040". Cranking Cr is 170-180psi with XE274H cam.
