MSD Blaster 2 mounting position #1421948
04/19/13 12:16 AM
04/19/13 12:16 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Hello again.
I'm installing a reproduction wiring harness in the 70 Charger. For several years, I had the coil mounted vertically on the RH fender apron near the alternator. The coil wiring isn't long enough to reach that position, so I'm thinking of mounting the coil on the intake in front of the carburetor, like stock. Putting it there will look cleaner and the wires will reach.
The instructions that came with the MSD coil are a little vague. They state that the coil is designed to use the factory mounting brackets but later it reads that mounting the coil vertically is recommended. All the factory coils were mounted horizontally, right? What could be different about the MSD coil to warrant a different position?
Who has actually had trouble with their coils by mounting them on the side?
Yeah... I could just solder in longer wires to reach the fender apron, but I sorta like the idea of cleaning up the area to look less cluttered.
Opinions?
Re: MSD Blaster 2 mounting position [Re: Kern Dog] #1421949
04/19/13 02:16 AM
04/19/13 02:16 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I just read on the MSD website that their reasoning seems to be that since the coils are oil filled, they recommend an upright position. It didn't say it was mandatory, just recommended. The factory coils were oil filled too, so what the heck?
Re: MSD Blaster 2 mounting position [Re: Kern Dog] #1421950
04/19/13 02:22 AM
04/19/13 02:22 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Lack of confidence in their manufacturing procedures?
Re: MSD Blaster 2 mounting position [Re: Kern Dog] #1421951
04/19/13 02:24 AM
04/19/13 02:24 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Mancini sells this cool bracket that AndyF makes...
Re: MSD Blaster 2 mounting position [Re: 1_WILD_RT] #1421952
04/19/13 02:56 AM
04/19/13 02:56 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Hmmm, I guess I can build one just like that tomorrow!
I actually enjoy making brackets. I don't know why I didn't think of that myself!
Thanks a bunch!
Re: MSD Blaster 2 mounting position [Re: Scott Carl] #1421953
04/19/13 10:21 AM
04/19/13 10:21 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Any oil-filled coil has a tiny air pocket (to allow for heat expansion.)
When mounted on their side, the air pocket *can* expose some of the windings, causing impoper cooling and damaging the coil.
Many coils are mounted sideways (including mine)and are fine. But upright is ideal.
Epoxy coils do not have this issue.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: MSD Blaster 2 mounting position [Re: wingman] #1421954
04/19/13 10:31 AM
04/19/13 10:31 AM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
I have been using a MSD blaster 2 coil for over 15 years mounted on it's side. No problems.
I have had coils leak oil in other cars in the past but not this one.
Re: MSD Blaster 2 mounting position [Re: patosmith] #1421955
04/19/13 10:43 AM
04/19/13 10:43 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Over the last 40 years I've mounted coils vertically & horizontally, and the only one I can recall leaking was on a SB '57 Chevy I'd bought and it was vertical.
The MSD B2 coil on my Roadrunner has been horizontal in the stock location since 1988.
Re: MSD Blaster 2 mounting position [Re: topside] #1421956
04/20/13 09:25 AM
04/20/13 09:25 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
My Blaster has been mounted on it's side as long as it's been in the car (a long time). No problems/issues.
I do like the mounting bracket on the BB pictured though (clean).
Re: MSD Blaster 2 mounting position [Re: Kern Dog] #1421957
04/20/13 05:44 PM
04/20/13 05:44 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Hello again.
Opinions?
They have a black anti-vibration, epoxy filled coil that can be mounted in any position. peel the label off and it looks stock
