Octane level and 2012 Ram 5.7 engine. #1421837
04/18/13 04:57 PM
04/18/13 04:57 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Manual says mid grade of 89. If I need gas and 89 is not available should I run 92 or 87 octane? Does the engine computer adjust for the difference. Does it even matter?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Octane level and 2012 Ram 5.7 engine. [Re: Junky] #1421838
04/18/13 05:19 PM
04/18/13 05:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Our 05 durango with a hemi says the same thing, 89 octane. We have ran 50K miles now with mostly 87. When we do put some premium on top of the 87 it does run better. So far so good and it has 100K on it now.
Re: Octane level and 2012 Ram 5.7 engine. [Re: Junky] #1421839
04/18/13 05:21 PM
04/18/13 05:21 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
mine says 89 recommended, 87 OK, but it is an earlier generation. Follow the manual. If is says 87 Acceptable, then OK. Anything higher (92+) is fine, it won't hurt anything. You just are paying more for a tank of gas
I wouldn't tow or haul with 87, especially in hot weather.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Octane level and 2012 Ram 5.7 engine. [Re: VincentVega] #1421840
04/18/13 07:08 PM
04/18/13 07:08 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
My 2011 Ram also recommends 89, but 90% of the time it gets 87. I do treat it to some 93 once in a while, but I really don't notice any difference in the way it runs.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Octane level and 2012 Ram 5.7 engine. [Re: 68LAR] #1421841
04/18/13 08:37 PM
04/18/13 08:37 PM
IN
ahy Offline
ahy  Offline
IN
I've had 3 and they always call for 89. I run higher if its not available. With 87 you are depending on the knock sensor to take timing out to keep the engine healthy. One time this question came up, a poster said he always ran 87 until a piston got "holed" at 50k. After repairs he ran 89+. I guess his knock sensor wasn't up to snuff.
Re: Octane level and 2012 Ram 5.7 engine. [Re: ahy] #1421842
04/18/13 08:43 PM
04/18/13 08:43 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
89 is 50/50 mix of 87 and 92
Re: Octane level and 2012 Ram 5.7 engine. [Re: 68LAR] #1421843
04/18/13 09:00 PM
04/18/13 09:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
Same for my 2010 2500
The motor isn't likely to detonate unless overheated or under heavy load. Under normal operating conditions, daily driving, you aren't likely to experience any adverse effects. If you are towing heavy, working the truck hard or its hot out, probably better off with the 89.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Octane level and 2012 Ram 5.7 engine. [Re: 05dakota] #1421844
04/18/13 09:01 PM
04/18/13 09:01 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Assuming the knock sensor is working it will cause timing to be pulled out if it senses detonation reducing performance and fuel economy to save the engine.
I know this is way off topic but I had a 98 GTP which called for 92 in the manual. It ran noticeably worse with anything less than that (only did it a few times). Under load it would detonate and you could literally feel the timing get pulled when it occurred. I liked to run Sunoco 94 in it which made it run even better. No joke.
Given the choice between low and high grade, run higher if you can. In the grand scheme of things it is only a couple of bucks more.
383, Hemi 4-Speed, AlterKtion, D60
Re: Octane level and 2012 Ram 5.7 engine. [Re: ahy] #1421845
04/18/13 09:06 PM
04/18/13 09:06 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Had the same thing happen to me at approximately 100K miles on the way back from Carlisle. Drove it back pulling a trailer with 2 burned pistons. Got 5 MPG, but it made it !
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Octane level and 2012 Ram 5.7 engine. [Re: Dixie] #1421846
04/18/13 09:29 PM
04/18/13 09:29 PM
Cincinnati, Ohio
Cincinnati, Ohio
Whoo, I have always ran premium when towing in any vehicle. They are working really hard as you know now, so sorry to hear that.
My wife drives her durango to work and back for the most part. We don't tow much with our hemi, I have a dually for that. But now you guys are scaring me into mid grade more often.
Re: Octane level and 2012 Ram 5.7 engine. [Re: Challenger 1] #1421847
04/18/13 09:57 PM
04/18/13 09:57 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Good info, guys. Keep 'em coming.
Question: Will running 92 give better mileage offsetting the slightly higher cost over 89 octane?
Re: Octane level and 2012 Ram 5.7 engine. [Re: Junky] #1421848
04/18/13 10:07 PM
04/18/13 10:07 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Nope. Running more octane than you need is a waste - it's actually slightly less efficient (unless, as stated, your engine is running hot/pinging/detonating when it shouldn't be). Octane is introduced as a chemical, and 92 will have more of it, and it will actually retard the burn in addition to displacing some of the gasoline. That means slightly lower energy content. That's why, unless the engine needs it, it's a double waste to run extra octane.
Re: Octane level and 2012 Ram 5.7 engine. [Re: VincentVega] #1421849
04/18/13 10:18 PM
04/18/13 10:18 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
Absolutely and well stated!!
Re: Octane level and 2012 Ram 5.7 engine. [Re: VincentVega] #1421850
04/19/13 12:24 AM
04/19/13 12:24 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I see, I was hoping the computer would recognize the higher octane and advance the timing a bit resulting in a slight horse power increase and mileage.
Re: Octane level and 2012 Ram 5.7 engine. [Re: Junky] #1421851
04/19/13 01:35 AM
04/19/13 01:35 AM
Sobieski Wi
bee1971 Online work
bee1971  Online Work
Sobieski Wi
My 2011 has never seen 89 Octane so far
My 2004 never saw 89 Octane in 50,000 miles either
Right from the owners manual
87 Octane Acceptable. 89 Octane
Recommended.
Component Fluid, Lubricant, or Genuine Part Capacities
Fuel Selection
3.7L, 4.7L
87 Octane 1500 Regular Cab
Shortbed/Crew Quad
Cab - 26 Gallons
(98 Liters) 1500
Regular Cab
Longbed/Crew Quad
Cab (Optional) -
32 Gallons (121 Liters)
2500/3500 Shortbed -
34 Gallons (129 Liters)
2500/3500 Longbed -
35 Gallons (132 Liters)
Fuel Selection
5.7L
Recommended.
1500 Regular Cab
Shortbed/Crew Quad
Cab - 26 Gallons
(98 Liters) 1500
Regular Cab
Longbed/Crew Quad
Cab (Optional) -
2500/3500 Longbed -
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Octane level and 2012 Ram 5.7 engine. [Re: bee1971] #1421852
04/19/13 01:45 AM
04/19/13 01:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The truck version of the 5.7 made about the same power for several years. The 2003-2007 was 345 HP. I had a 2006 and I currently have a 2007, both with the 5.7. I'm at 160,000 miles and have rarely used anything but 87 octane. I have been unable to tell any difference in performance.
The newer versions may require higher octane. I often defer to the glovebox manual to be safe.
Re: Octane level and 2012 Ram 5.7 engine. [Re: Kern Dog] #1421853
04/19/13 09:47 AM
04/19/13 09:47 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I rarely romp on my hemi, but I did think once I could tell the difference between 87 and 89. As I mentioned earlier, it does say 87 acceptable in the booklet, but this is a Gen 1 and I don't know if the newer ones say it.
I thought it ran up through the RPMs a little better on 89. They're fairly loud even stock muffled, so it's probably hard to hear pinging/knocking. Like most said, on 87, it's no doubt going to retard timing now and then. But it shouldn't cause damage unless you abuse the vehicle, have a lot of carbon deposits, or are doing heavy towing
Re: Octane level and 2012 Ram 5.7 engine. [Re: Junky] #1421854
04/19/13 10:11 AM
04/19/13 10:11 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
no.
my 2011 charger owners manual says 89 recommended, 87 acceptable. I've run both and haven't seen a lick of difference in performance or fuel economy. I'd run 87, but if you plan on towing, where the engine is going to be under heavy load and generating more heat, then I'd probably fill up with 91+....
FWIW, a while back on one of the LX forums, someone did dyno testing of a stock 5.7 chally with different grades of gas...IIRC it made 328 at the rear wheels with 89, 325 with 87, and 323 with 91 or 92....
2017 Grand Cherokee Overland
Re: Octane level and 2012 Ram 5.7 engine. [Re: patrick] #1421855
04/19/13 11:11 AM
04/19/13 11:11 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My '12 has about 11,000 miles and has never had anything but 87 in it. Gets 14.5 mpg in the winter and almost 17 in the summer.
Re: Octane level and 2012 Ram 5.7 engine. [Re: Crazy68Dart] #1421856
04/19/13 12:08 PM
04/19/13 12:08 PM
Renton Washington
Renton Washington
Those of you who say you can feel a difference between 87 and 89 are noticing a placebo effect. I've made 1/4 mile runs with 87 and with 89, there is not a dramatic difference.
-Dustin
