Re: Octane level and 2012 Ram 5.7 engine.
[Re: Junky]
#1421838
04/18/13 05:19 PM
04/18/13 05:19 PM
Challenger 1
Cincinnati, Ohio
Manual says mid grade of 89. If I need gas and 89 is not available should I run 92 or 87 octane? Does the engine computer adjust for the difference. Does it even matter?
Our 05 durango with a hemi says the same thing, 89 octane. We have ran 50K miles now with mostly 87. When we do put some premium on top of the 87 it does run better. So far so good and it has 100K on it now.
[Re: Junky]
#1421839
04/18/13 05:21 PM
04/18/13 05:21 PM
Posts: 1,106 Northeast
VincentVega
Northeast
mine says 89 recommended, 87 OK, but it is an earlier generation. Follow the manual. If is says 87 Acceptable, then OK. Anything higher (92+) is fine, it won't hurt anything. You just are paying more for a tank of gas
I wouldn't tow or haul with 87, especially in hot weather.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: 68LAR]
#1421843
04/18/13 09:00 PM
04/18/13 09:00 PM
Triple Threat
Renton Washington
My 2011 Ram also recommends 89, but 90% of the time it gets 87. I do treat it to some 93 once in a while, but I really don't notice any difference in the way it runs.
Same for my 2010 2500
I've had 3 and they always call for 89. I run higher if its not available. With 87 you are depending on the knock sensor to take timing out to keep the engine healthy. One time this question came up, a poster said he always ran 87 until a piston got "holed" at 50k. After repairs he ran 89+. I guess his knock sensor wasn't up to snuff.
The motor isn't likely to detonate unless overheated or under heavy load. Under normal operating conditions, daily driving, you aren't likely to experience any adverse effects. If you are towing heavy, working the truck hard or its hot out, probably better off with the 89.
[Re: 05dakota]
#1421844
04/18/13 09:01 PM
04/18/13 09:01 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Assuming the knock sensor is working it will cause timing to be pulled out if it senses detonation reducing performance and fuel economy to save the engine.
I know this is way off topic but I had a 98 GTP which called for 92 in the manual. It ran noticeably worse with anything less than that (only did it a few times). Under load it would detonate and you could literally feel the timing get pulled when it occurred. I liked to run Sunoco 94 in it which made it run even better. No joke.
Given the choice between low and high grade, run higher if you can. In the grand scheme of things it is only a couple of bucks more.
383, Hemi 4-Speed, AlterKtion, D60
[Re: ahy]
#1421845
04/18/13 09:06 PM
04/18/13 09:06 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Had the same thing happen to me at approximately 100K miles on the way back from Carlisle. Drove it back pulling a trailer with 2 burned pistons. Got 5 MPG, but it made it !
[Re: Dixie]
#1421846
04/18/13 09:29 PM
04/18/13 09:29 PM
Challenger 1
Cincinnati, Ohio
Whoo, I have always ran premium when towing in any vehicle. They are working really hard as you know now, so sorry to hear that.
My wife drives her durango to work and back for the most part. We don't tow much with our hemi, I have a dually for that. But now you guys are scaring me into mid grade more often.
[Re: Junky]
#1421848
04/18/13 10:07 PM
04/18/13 10:07 PM
VincentVega
Northeast
Nope. Running more octane than you need is a waste - it's actually slightly less efficient (unless, as stated, your engine is running hot/pinging/detonating when it shouldn't be). Octane is introduced as a chemical, and 92 will have more of it, and it will actually retard the burn in addition to displacing some of the gasoline. That means slightly lower energy content. That's why, unless the engine needs it, it's a double waste to run extra octane.
[Re: VincentVega]
#1421849
04/18/13 10:18 PM
04/18/13 10:18 PM
Posts: 4,954 WI
Dcuda69
WI
Absolutely and well stated!!
[Re: Junky]
#1421851
04/19/13 01:35 AM
04/19/13 01:35 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
My 2011 has never seen 89 Octane so far
My 2004 never saw 89 Octane in 50,000 miles either
Right from the owners manual
87 Octane Acceptable. 89 Octane Recommended.
Component Fluid, Lubricant, or Genuine Part Capacities Fuel Selection 3.7L, 4.7L 87 Octane 1500 Regular Cab Shortbed/Crew Quad Cab - 26 Gallons (98 Liters) 1500 Regular Cab Longbed/Crew Quad Cab (Optional) - 32 Gallons (121 Liters) 2500/3500 Shortbed - 34 Gallons (129 Liters) 2500/3500 Longbed - 35 Gallons (132 Liters) Fuel Selection 5.7L 87 Octane Acceptable. 89 Octane Recommended. 1500 Regular Cab Shortbed/Crew Quad Cab - 26 Gallons (98 Liters) 1500 Regular Cab Longbed/Crew Quad Cab (Optional) - 32 Gallons (121 Liters) 2500/3500 Shortbed - 34 Gallons (129 Liters) 2500/3500 Longbed - 35 Gallons (132 Liters)
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Kern Dog]
#1421853
04/19/13 09:47 AM
04/19/13 09:47 AM
VincentVega
Northeast
I rarely romp on my hemi, but I did think once I could tell the difference between 87 and 89. As I mentioned earlier, it does say 87 acceptable in the booklet, but this is a Gen 1 and I don't know if the newer ones say it.
I thought it ran up through the RPMs a little better on 89. They're fairly loud even stock muffled, so it's probably hard to hear pinging/knocking. Like most said, on 87, it's no doubt going to retard timing now and then. But it shouldn't cause damage unless you abuse the vehicle, have a lot of carbon deposits, or are doing heavy towing
[Re: Junky]
#1421854
04/19/13 10:11 AM
04/19/13 10:11 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Good info, guys. Keep 'em coming.
Question: Will running 92 give better mileage offsetting the slightly higher cost over 89 octane?
no.
my 2011 charger owners manual says 89 recommended, 87 acceptable. I've run both and haven't seen a lick of difference in performance or fuel economy. I'd run 87, but if you plan on towing, where the engine is going to be under heavy load and generating more heat, then I'd probably fill up with 91+....
FWIW, a while back on one of the LX forums, someone did dyno testing of a stock 5.7 chally with different grades of gas...IIRC it made 328 at the rear wheels with 89, 325 with 87, and 323 with 91 or 92....
[Re: Crazy68Dart]
#1421856
04/19/13 12:08 PM
04/19/13 12:08 PM
Triple Threat
Renton Washington
Those of you who say you can feel a difference between 87 and 89 are noticing a placebo effect. I've made 1/4 mile runs with 87 and with 89, there is not a dramatic difference.
[Re: VincentVega]
#1421857
04/19/13 01:28 PM
04/19/13 01:28 PM
dogdays
Cousin Vinny, you said, "Octane is introduced as a chemical, and 92 will have more of it, and it will actually retard the burn in addition to displacing some of the gasoline. That means slightly lower energy content." This statement is absolutely wrong. Octane is a specific hydrocarbon molecule. I believe the reference molecule is 1,1,1 Isooctane. When knock resistance became an issue, a reference was needed, just as 100 degrees Celsius was originally pegged as the boiling point of water. A fuel of 100 octane will have the same knock characteristics in the "official" SAE knock test engine as fuel made up of 100% 1,1,1 Isooctane. Octane is NOT "introduced" into the fuel. The octane rating is an inherent property of the specific fuel. Higher octane fuels ignite and burn more slowly than lower octane fuels. They may or may not have less energy per weight or volume depending on the supplier, refineries, etc. Thus, using a higher-than-recommended octane rated fuel may lower power or efficiency because of incomplete combustion. One thing for sure, using fuel with a higher octane rating than the engine demands costs more. Another thing, temperature plays an enormous role in determining whether an engine will knock on a given fuel or not. One car I have will run on midgrade in the wintertime but when outside air temps get close to 90F it has to have premium or it knocks even with the knock sensor pulling out timing. Last thing, many GM products of the '80s and '90s had a very aggressive engine protection plan programmed into their computers. At the first hint of knock, a whole bunch of timing was pulled, like 9 or 10 degrees. The return to "normal" timing was also very slow. In these vehicles, if a lower octane fuel was tried, mileage and power suffered dramatically. Other manufacturers probably did the same thing, I'm not sure. R.
