timing adjustments #1421772
04/18/13 03:42 PM
04/18/13 03:42 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
When timing the engine how much should the mark jump around from 0 at idle? Should it be pretty steady or jump back and forth 5-10 degrees? I'm having a hard time finding my intial with the mark bouncing all over. What would cause it to bounce?
Re: timing adjustments [Re: wtucker] #1421773
04/18/13 04:01 PM
04/18/13 04:01 PM
sloppy timing chain/gears and or dist lower tang in the inter gear rotational slop. Put the timing marks at TDC with the rotor on #1 then pull the pass valve cover & move the crank back & forth a bit & see how much travel you have till it makes one of #6 cyls' rocker arms start to move which'll tell you how much chain play you have. With your hand turn the rotor back & forth lightly to see how much tang play you have & dont turn hard enough to get into the springs. An aluminum 1/2" ID collar on the bottom of the shaft will elim alot of that. McMasters/Carr & others sell them. Make sure your timing light is hooked up securely
Re: timing adjustments [Re: RapidRobert] #1421774
04/18/13 04:32 PM
04/18/13 04:32 PM
Penna
70satelliteguy Offline
Penna
They all jump around some unless you go to a Crank trigger!
Mike
Re: timing adjustments [Re: 70satelliteguy] #1421775
04/18/13 06:47 PM
04/18/13 06:47 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have put the dist shaft across the back of a vice and give the tang a tap with a hammer on both ends to tighten it in the slot.
But dont get carried away.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: timing adjustments [Re: deaks] #1421776
04/18/13 06:59 PM
04/18/13 06:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Be sure the vacuum advance hose is disconnected.
Re: timing adjustments [Re: wtucker] #1421777
04/18/13 08:18 PM
04/18/13 08:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Broken or too loose springs in the dist will cause it jump around at idle also. My eddie headed 474 cammed 340 stays within 2 degrees at idle but at one point I had too loose of springs in there and the timing moved around at idle. I bend the tang that the spring attaches to in the dist to fine tune it.
